channel change duration problem
Postby ibrahimfsasmaz » Mon Jan 24, 2011 11:23 pm
I am using "tbs 6981" with "dvblink tv source" "win7ult x64" via "windows media center" interface.
While changing the channels it is waiting 8-10 seconds, I am having black screen during this time.
I think it is too long, 8 sec. ?
How can I fix it please ?
ibrahimfsasmaz
Re: channel change duration problem
Postby cody » Tue Jan 25, 2011 1:04 am
hi, i've just answered to your e-mail, but let me say it here again - i think you use driver version older than the latest 2.0.0.14 and that's why you have such problem.
Postby ibrahimfsasmaz » Tue Jan 25, 2011 11:07 pm
Hello
I got your email thanks a lot.
But it looks like something different.
Because I am using the driver that you suggest.
Do you have any other idea ?
ibrahimfsasmaz
Postby cody » Wed Jan 26, 2011 3:55 am
hi, if you use the latest driver version 2.0.0.14 then we can be sure the slow channel change is not due to driver bug, because that version changes the channels very fast. so, we need to rule out problem with the software - for example problem with video/audio codecs. what i can suggest is to use TransEdit - select transponder there, then press "Analyze" button and see how much time it takes for TransEdit to get lock on the transponder. TransEdit doesn't use video/audio codecs and just receives the data from the satellite and analyze them and that's why it can give good clues where the problem is - for example if TransEdit gets fast lock then for sure it's not your TBS 6981 hardware or drivers, but some software settings, etc.
Postby ibrahimfsasmaz » Wed Jan 26, 2011 4:29 am
Probably you have right, the problem is not directly from tbs, some driver or software is not matching with tbs .
But I have no idea which one ?
Where can I download the transedit please ? I will try this
ibrahimfsasmaz
Postby BluetoothBG » Wed Jan 26, 2011 6:46 am
You can try downloading v3.6.0 from here - http://www.megaupload.com/?d=JNDTIYH3
It is not the latest, but it'll do the work.
Sofia, Bulgaria
TBS 6981 DVB-S/S2 | Triax TD88 | Inverto 0.2dB TWIN @ { 39E, 45E }
TBS 6921 DVB-S/S2 | Triax TD78 | Inverto 0.2dB TWIN @ { 0.8W }
BluetoothBG
Postby ibrahimfsasmaz » Thu Jan 27, 2011 9:26 pm
Hello
This file does not work, could you please give me an other link ?
ibrahimfsasmaz
Postby ssenyer » Thu Jan 27, 2011 10:50 pm
Hi all,
It is DVBLink's problem, not related with hardware or driver. Since i had same problem when i was using DVBlink+Mediaportal i can say that clearly the problem is DVBLink.
Turkish:
Selam,
Sorun DVBLink te. Ben de mediaportal altında DVBLink kullanıyordum ve kanal geçişleri dediğin gibi 7-8 sn alıyordu. Sonra DVBLinki iptal ederek sadece mediaportal kullanarak denedim. Bu şekilde kanal geçiş süreleri 1 sn civarındaydı, hatta bir saniyenin altında. Başka bir programla örneğin TSB'nin Cd sinde bulunan DVBSource ile dener misin?
ssenyer
Postby ibrahimfsasmaz » Thu Jan 27, 2011 11:26 pm
Haydi buyrun :) döndük başa... Tam çözüme yaklaştığımı düşümnüyordum...
Öncelikle derdime sizden cevap alabilmek beni çok mutlu etti, artık Türkler heryerde ne güzel, çok sevindim
Şimdi asıl problem şurada, bilemiyorum siz nasıl bir konfigürasyon kullanıyorsunuz ama win7 nin kendi altında Turksat 2a 3a yı hiçbir şekilde tanıtmak mümkün değil,microsoft a yazıp çizince de topu hep taça atıyorlar, çözüm üretmiyorlar.
Yani kartı direk win7 media center a tanıtarak türksat izlemek mümkün değil. Daha önce dvbdream, dvbviewer gibi çok fazla yazılım denedim, ya çalışmadılar, ya sorunlu çalıştılar ya da arayüzleri berbattı.
Dvblink TV Source alternatifi bir ara yazılım bulmaya çalıştım onu da bulamadım.
Sizin bu söylediğiniz cd den çıkan DvbSource yine bir bağlantı yazılımı mı ? Yani arayüz Windows Media Center mı olacak yoksa diğer yazılımlar gibi kendi arayüzü mü var ?
Teşekkürler
ibrahimfsasmaz
Postby ibrahimfsasmaz » Thu Jan 27, 2011 11:31 pm
Bakın bir de bu var web sitesinde, bunu mu kastediyorsunuz ?
Yani dvdlink i tbs ye adapte mi etmişler ?
http://www.tbsdtv.com/english/Download.html
DVBLogic ( DVBLinkTVSourceTBS )
TBS reached agreement with DVBlogic. TBS TV tuner card user will receive a 10% discount from the usual price when buying DVBlogic.
DVBLogic updates the DVBLinkTVSourceTBS to version V32. The new version adds support to TBS8921, TBS6921 and TBS6981
ibrahimfsasmaz
