Diseqc 1.0 problem
Diseqc 1.0 problem
Postby sumon » Tue Nov 08, 2011 11:33 am
I can't switch satellite while watching one channel from one satellite then try to go to another satellite to watch another channel.
Watching from one Sat is Ok except few channel has Freeze picture on VLC and no picture on Server media centre. But Iphone works fine on those channel.
Very strange. Main issue is if I change channel from one satellite channel like optus D2 to another channel in Optus C1 then I get error.
All people out there please bring some light into it..
Here is my log file.
Can anyone review my file...
dvblink_debugview.rar
Log file
(15.68 KiB) Downloaded 327 times
My Satellite Card is TBS 8921,Operation system Windows 7 (64 Bit),DVBlink ( latest version 4.0),CPU Core 2 Duo E7400 @ 2.8 GHz, 4 GB RAM.
Satellite Info
Port 1= A/A Set up for Optus D2
Port 3=B/A set up for Optus C1
port 4 =B/B satup for Asiasat 4
sumon
Re: Diseqc 1.0 problem
Postby steven » Wed Nov 09, 2011 9:43 pm
Hi sumon
maybe DVBLink which you are use can not send diseqc,
would you mind try this version from our download page:
http://www.tbsdtv.com/download/common/D ... v3.2.2.zip
Postby sumon » Thu Nov 10, 2011 7:30 am
steven Wrote:Hi sumon
No luck..
I had the same problem on Version 3.2.2..
Please check my log file...to get more info..
Satellite Info
sumon
