TBS5925-BlindScan.exe, why are parameters in L-Band...
Postby User5925 » Sun Nov 06, 2011 10:27 pm
Probably 99 percent of users will be totally confused that the frequency range is not the published satellite transponder frequencies.
There should also be a setting for the 22KHz tone that will automatically follow/adjust-to the frequency band.
User5925
Re: TBS5925-BlindScan.exe, why are parameters in L-Band...
Postby starman345 » Sun Nov 06, 2011 11:22 pm
seems sttrange they are doing the same thing with the 5925 as with the 8921 months ago...Read here:
viewtopic.php?f=27&t=191
10' dish- Bullseye II c/ku
55.5W to 139W
Windows 8.1 64 bit
TBS 8922 Prof 7301 TBS 6925
starman345
Postby steven » Fri Nov 18, 2011 11:59 am
Hi User5925
About the Blindscan input frequency range is not the published satellite transponder frequencies.
We are updating this now,and new version will be released soon.
Postby Peon » Fri Nov 18, 2011 11:31 pm
Indication tuning is nonlinear. 10% pre-tuning = 95% indication :oops: . It would be an indication of the current scanning frequency. :!: Thanks
Peon
Postby Peon » Sun Feb 19, 2012 6:41 pm
Hi steven,
A new version ( 3.0.0.9) has no change in the entering of frequencies :(
Peon
Postby steven » Tue Feb 21, 2012 2:13 pm
Hi Peon
This new version added all scan for L/H band.
Next week, I will give you a beta version which can enter frequence. : )
Postby steven » Fri Feb 24, 2012 3:16 pm
Hi Peon
Here is the new version which have used the satellite frequence .
Hers is the linker:
http://hotfile.com/dl/147624251/ec25c21/tbs-blindscan_v3.0.1.0.zip.html
Would you mind using this new version to have a test.if have any problem, just contact me. :D
Best regards
Postby Peon » Sat Feb 25, 2012 1:50 am
Hi Steven
Thank you. But it works only in the Ku band. The C band is not. Can not scan. Not accept the entry of any frequency. Please fix.
Best Regards
Peon
Postby steven » Mon Feb 27, 2012 4:11 pm
Hi Peon
Thanks for your test report.
And here is the new version.
Would you mind having a test again. :D
Here is the file linker:
http://hotfile.com/dl/147984471/3484fcd/tbs-blindscan_v3.0.1.0.zip.html
Best regards
Postby starman345 » Mon Feb 27, 2012 9:24 pm
With the new test version, and my TBS 8922 ku band blind scanning works fine, on C band, all transponders are scanned correctly if I select pol:v or pol:h, however if I select pol:ALL then only v is scanned, then the program quickly reports total number of found transponders, it seems h is not scanned when pol:ALL is selected.
55.5W to 139W
Windows 8.1 64 bit
starman345
