TBS 6928, Jolly 1.01 CAM, and DVB Viewer
Postby ncarlson » Sun Nov 06, 2011 1:38 am
I have the TBS 6928 with a Jolly 1.01 CAM (technically identical to a Diablo 2.3). I use DVBViewer. I can view and also record encrypted channels correctly in the DVBViewer program. However, when I use the DVBViewer Recording Service, the channels only record properly when I have the channel tuned in the DVBViewer program. Otherwise, if the DVBViewer program is closed but the Recording Service tries to record an encrypted channel, the channel is not decrypted by the CAM and is thus not recorded properly.
It seems that the DVBViewer Recording Service does not know how to activate the CAM in the TBS 6928, but only in the DVBViewer program.
I have another computer configured with a FloppyDTV-S2 with the Jolly CAM. The DVBViewer Recording Service works perfectly with it, so I know that this is a problem that can be solved.
Can you help? Maybe I don’t have the DLL installed correctly? Or is this something you still need to work out with DVBViewer? Thanks.
ncarlson
Re: TBS 6928, Jolly 1.01 CAM, and DVB Viewer
Postby steven » Wed Nov 09, 2011 9:14 pm
Hi ncarlson
Sorrry for the problem you have met,we will contact DVBViewer and look into our DLL to find the problem
and give you an answer as soon as possible.
Postby ncarlson » Fri Nov 11, 2011 2:25 am
Hey, Steven--thanks, I'll hang tight till then...
ncarlson
Postby JoeH » Sun Nov 20, 2011 4:39 pm
I am also interested in this one. Looking forward to support for DVBViewer Recording Service. Thanks!
JoeH
Postby luchy » Tue Nov 22, 2011 10:11 am
hi all,
we have tested under dvbviewer pro and gotten the same question.there is not dll decryption question.
after contacted dvbviewer, he need more info to this question, can you provide the support.zip to following?
http://www.dvbviewer.tv/forum/topic/221 ... correctly/
luchy
Postby ncarlson » Fri Dec 02, 2011 2:20 am
Here's the support.zip...is this right?
support.zip
(87.99 KiB) Downloaded 618 times
ncarlson
Postby JoeH » Thu Feb 23, 2012 5:17 pm
Any update on this? How's it coming? Any estimated time of arrival? Thanks!
JoeH
Postby JoeH » Wed Mar 14, 2012 1:12 am
Bump.
JoeH
Postby steven » Mon Apr 16, 2012 9:33 am
Hi JoeH
Sorry for the delay reply,This is DVBViewer's problem,the way we can do is contact DVBViewer to solve this
Problem.
Before solve this problem,we advise you to use 4TheRecord which is full compatible with TBS6928.
Here is the linker:
http://www.fortherecord.tv/
You can get more information about this.
Postby herrbasan » Thu May 24, 2012 6:00 pm
Intel i5-2400 / Windows 7 x64
TvCard: TBS 9628 / Treiber: v1.0.1.2
CAM: Unicam Deltracrypt / Sparta 5.34 / V13 Sky Germany Card
Recording Service: V1.9.7.0
I Seem to have a similar or related problem. The DVBViewer Recording service can access the card and the CAM once after a fresh start of the service, but then any second attempt to tune to an encrypted channel fails. To me it seems that the Recording Service or the Driver don't release the CAM after the first use. The DVBViewer Application can access the Card and CAM directly, even in the "locked up state", but the RS can access the CAM only after a restart of the service. Tested probably a hundred times, the problem is 100% reliable :)
It's quite frustrating, since the TBS Card is by far the best solution i've ever seen, and i own a lot of TV-Cards. So i'm very eager to get this working.
The Developer of the DVBViewer points to the driver. Please Help.
Edit: Just noticed there is a new driver available .. i'm so excited :) I'll let you know if it solves my problems.
Edit: Unfortunately the new driver doesn't resolve my problem. :(
TBS 6928 / Unicam Deltracrypt CAM / Sky Germany V13 Card
Windows 7 x64 / MediaPortal 1.2.3
herrbasan
