BSOD in TBS6984_64.sys - Windows 7 64 Bit
Postby digitalmischief » Sat Nov 05, 2011 5:13 am
I've had the card about a week a so far its been ok but tonight whilst recording two channels in MCE through DVBLink the following BSOD happened,
I am on driver version :
1.0.1.3 (26/08/2011) TBSDTV TECHNOLOGY
help!
Toby
digitalmischief
Re: BSOD in TBS6984_64.sys - Windows 7 64 Bit
Postby smile » Mon Nov 07, 2011 10:14 am
Hi digitalmischief
Would you mind try to use DVB Dream or TBSViewer without use DVBLink.and do you have tested it in windows 7 32Bit ?
smile
Postby digitalmischief » Mon Nov 07, 2011 4:52 pm
its only happened once so far (with me using the media center every night) so its not something that I can reproduce easily. I will see if it happens again. Are you aware of any issues on 64 bit windows? Is stability known to be better on 32bit?
cheers
digitalmischief
