[ Moderator Control Panel ]
by sorrowrock » Fri Nov 04, 2011 11:23 pm
When is use program with tuner A
I'm working with tps ip data with tuner A
I re-run tps ip data for use the second tuner
The program will not run
Where is the problem?
sorrowrock
by steven » Wed Nov 09, 2011 9:28 pm
Hi sorrowrock
Sorry for the problem,we will have a check later,and give you an answer as soon as possible.
