[ Moderator Control Panel ]
by onesixright » Tue Dec 13, 2011 3:43 am
hi Wim,
Did you find out anything, i just ordered this card, and looking which CAM to buy. Hope you got a bit further.
Thanks,
16R
onesixright
by cody » Wed Dec 14, 2011 2:26 am
of course, we can't test all available CAMs, but there is no difference in CAM compatibility between Linux than Windows - the compatibility is the same. so, i believe the Aston CAM will work.
by warumnix » Fri Dec 23, 2011 3:36 pm
Hi Wim,
we have bought those two CAMs, and just tested in lab, they are supported
regards
warumnix
warumnix
