Frontend module issues
Postby Drae » Thu Oct 20, 2011 1:48 am
This is really a follow on to a previous topic in this forum. After a period of time - usually following a period of inactivity (i.e. no streaming) tvheadend basically fails to stream any data. When I look at dmesg I see the following:
[23505.674093] TurboSight TBS 5921 Frontend:
[23505.674096] tbs5921fe - command is not responding
[23505.674099] TurboSight TBS 5921 Frontend:
[23505.674099] tbs5921fe - running software failed
This is repeated until I power off, wait and power the Qbox back on. Simply rebooting is impossible. Equally I cannot rmmod (or modprobe -r) the relevant modules because they are "in use" despite no software on the system accessing them (i.e. tvheadend has been shut down). I do wonder if this is a firmware issue or perhaps a hardware problem - is it some incompatibility with tvheadend (I don't think so - least I don't think this is a tvheadend issue)? Whatever the issue it's pretty annoying that I must power cycle the qbox so regularly.
Drae
Re: Frontend module issues
Postby imperia » Fri Nov 25, 2011 6:03 am
I see similar errors in my log:
[16617.368176] TurboSight TBS 5921 Frontend:
[16617.368178] tbs5921fe - software version is 1.24.3
[16617.368184] TurboSight TBS 5921 Frontend:
[16617.368186] tbs5921fe - Successfully Initialized
[16672.708594] TurboSight TBS 5921 Frontend:
[16672.708597] tbs5921fe - software version is 1.24.3
[16672.708603] TurboSight TBS 5921 Frontend:
[16672.708605] tbs5921fe - Successfully Initialized
[17959.497523] TurboSight TBS 5921 Frontend:
[17959.497526] tbs5921fe - modulation 9 is not supported
[17962.937497] TurboSight TBS 5921 Frontend:
[17962.937500] tbs5921fe - modulation 9 is not supported
[17967.320213] TurboSight TBS 5921 Frontend:
[17967.320216] tbs5921fe - software version is 1.24.3
[17967.320222] TurboSight TBS 5921 Frontend:
[17967.320224] tbs5921fe - Successfully Initialized
[17970.264240] TurboSight TBS 5921 Frontend:
[17970.264243] tbs5921fe - software version is 1.24.3
[17970.264249] TurboSight TBS 5921 Frontend:
[17970.264251] tbs5921fe - Successfully Initialized
[17989.204235] TurboSight TBS 5921 Frontend:
[17989.204237] tbs5921fe - software version is 1.24.3
[17989.204243] TurboSight TBS 5921 Frontend:
[17989.204245] tbs5921fe - Successfully Initialized
[17995.208282] TurboSight TBS 5921 Frontend:
[17995.208285] tbs5921fe - software version is 1.24.3
[17995.208291] TurboSight TBS 5921 Frontend:
[17995.208293] tbs5921fe - Successfully Initialized
[18075.884227] TurboSight TBS 5921 Frontend:
[18075.884230] tbs5921fe - software version is 1.24.3
[18075.884237] TurboSight TBS 5921 Frontend:
[18075.884238] tbs5921fe - Successfully Initialized
[18090.676236] TurboSight TBS 5921 Frontend:
[18090.676239] tbs5921fe - software version is 1.24.3
[18090.676245] TurboSight TBS 5921 Frontend:
[18090.676247] tbs5921fe - Successfully Initialized
[18121.360208] TurboSight TBS 5921 Frontend:
[18121.360210] tbs5921fe - software version is 1.24.3
[18121.360216] TurboSight TBS 5921 Frontend:
[18121.360218] tbs5921fe - Successfully Initialized
[18125.624022] TurboSight TBS 5921 Frontend:
[18125.624028] tbs5921fe - command is not responding
[18125.624036] TurboSight TBS 5921 Frontend:
[18125.624037] tbs5921fe - running software failed
[18127.864238] TurboSight TBS 5921 Frontend:
[18127.864241] tbs5921fe - software version is 128.24.3
[18127.864247] TurboSight TBS 5921 Frontend:
[18127.864249] tbs5921fe - Successfully Initialized
[18157.421527] TurboSight TBS 5921 Frontend:
[18157.421530] tbs5921fe - modulation 9 is not supported
[18160.857521] TurboSight TBS 5921 Frontend:
[18160.857524] tbs5921fe - modulation 9 is not supported
[18174.076201] TurboSight TBS 5921 Frontend:
[18174.076204] tbs5921fe - software version is 1.24.3
[18174.076210] TurboSight TBS 5921 Frontend:
[18174.076211] tbs5921fe - Successfully Initialized
[18346.625381] TurboSight TBS 5921 Frontend:
[18346.625384] tbs5921fe - modulation 9 is not supported
[18350.085592] TurboSight TBS 5921 Frontend:
[18350.085595] tbs5921fe - modulation 9 is not supported
imperia
Postby cody » Fri Nov 25, 2011 11:43 pm
messages like this:
can be caused only by fault in your box and it need to be replaced with new one as part of the support/warranty process. in any case, because obviously such things as replacement can happen through a forum, which seems to me is a major reason why some users don't receive proper technical support i made a short article about how to report a problems:
viewtopic.php?f=32&t=2204
Tbsdtv Forum • Post a reply
Postby Liavady » Thu Dec 15, 2011 8:54 pm
I see similar errors in my log:[16617.368176] TurboSight TBS 5921 Frontend:[16617.368178] tbs5921fe - software version is 1.24.3[16617.368184] TurboSight TBS 5921 Frontend:[16617.368186] tbs5921fe - Successfully Initialized[16672.708594] TurboSight TBS 5921 Frontend:[16672.708597] tbs5921fe - software version is 1.24.3[16672.708603] TurboSight TBS 5921 Frontend:[16672.708605] tbs5921fe - Successfully Initialized[17959.497523] TurboSight TBS 5921 Frontend:[17959.497526] tbs5921fe - modulation 9 is not supported[17962.937497] TurboSight TBS 5921 Frontend:[17962.937500] tbs5921fe - modulation 9 is not supported[17967.320213] TurboSight TBS 5921 Frontend:[17967.320216] tbs5921fe - software version is 1.24.3[17967.320222] TurboSight TBS 5921 Frontend:[17967.320224] tbs5921fe - Successfully Initialized[17970.264240] TurboSight TBS 5921 Frontend:[17970.264243] tbs5921fe - software version is 1.24.3[17970.264249] TurboSight TBS 5921 Frontend:[17970.264251] tbs5921fe - Successfully Initialized[17989.204235] TurboSight TBS 5921 Frontend:[17989.204237] tbs5921fe - software version is 1.24.3[17989.204243] TurboSight TBS 5921 Frontend:[17989.204245] tbs5921fe - Successfully Initialized[17995.208282] TurboSight TBS 5921 Frontend:[17995.208285] tbs5921fe - software version is 1.24.3[17995.208291] TurboSight TBS 5921 Frontend:[17995.208293] tbs5921fe - Successfully Initialized[18075.884227] TurboSight TBS 5921 Frontend:[18075.884230] tbs5921fe - software version is 1.24.3[18075.884237] TurboSight TBS 5921 Frontend:[18075.884238] tbs5921fe - Successfully Initialized[18090.676236] TurboSight TBS 5921 Frontend:[18090.676239] tbs5921fe - software version is 1.24.3[18090.676245] TurboSight TBS 5921 Frontend:[18090.676247] tbs5921fe - Successfully Initialized[18121.360208] TurboSight TBS 5921 Frontend:[18121.360210] tbs5921fe - software version is 1.24.3[18121.360216] TurboSight TBS 5921 Frontend:[18121.360218] tbs5921fe - Successfully Initialized[18125.624022] TurboSight TBS 5921 Frontend:[18125.624028] tbs5921fe - command is not responding[18125.624036] TurboSight TBS 5921 Frontend:[18125.624037] tbs5921fe - running software failed[18127.864238] TurboSight TBS 5921 Frontend:[18127.864241] tbs5921fe - software version is 128.24.3[18127.864247] TurboSight TBS 5921 Frontend:[18127.864249] tbs5921fe - Successfully Initialized[18157.421527] TurboSight TBS 5921 Frontend:[18157.421530] tbs5921fe - modulation 9 is not supported[18160.857521] TurboSight TBS 5921 Frontend:[18160.857524] tbs5921fe - modulation 9 is not supported[18174.076201] TurboSight TBS 5921 Frontend:[18174.076204] tbs5921fe - software version is 1.24.3[18174.076210] TurboSight TBS 5921 Frontend:[18174.076211] tbs5921fe - Successfully Initialized[18346.625381] TurboSight TBS 5921 Frontend:[18346.625384] tbs5921fe - modulation 9 is not supported[18350.085592] TurboSight TBS 5921 Frontend:[18350.085595] tbs5921fe - modulation 9 is not supported
http://kimonogirls.x.fc2.com/
Liavady
