Linux Driver for Kernel 3.x Released
Postby warumnix » Thu Oct 13, 2011 1:54 pm
Hi All :D
Great news! TBS Linux driver for kernel 3.x is ready the same day as Ubuntu 11.10 official release!
Please check the download section:
http://www.tbsdtv.com/english/Download.html
warumnix
Re: Linux Driver for Kernel 3.x Released
Postby smv1210 » Sat Oct 15, 2011 7:42 pm
I think, You have nothing to be proud about - the driver does not work on Ubuntu 11.10 (i386):
http://pastebin.com/mE2JR3vV
smv1210
Postby steven » Thu Oct 20, 2011 12:04 pm
smv1210 Wrote:I think, You have nothing to be proud about - the driver does not work on Ubuntu 11.10 (i386):
We are working on this problem now,Please just wait for our good news.
Postby ferni » Tue Jan 31, 2012 3:09 pm
Should this be working?
I'm running ubuntu 11.10 x64 with kernel 3.2.0-12 and getting an error on the make
root@uhtpc:/home/andrew/Downloads/linux-tbs-drivers# make
make -C /home/andrew/Downloads/linux-tbs-drivers/v4l
make[1]: Entering directory `/home/andrew/Downloads/linux-tbs-drivers/v4l'
No version yet, using 3.2.0-12-generic
make[1]: Leaving directory `/home/andrew/Downloads/linux-tbs-drivers/v4l'
scripts/make_makefile.pl
Updating/Creating .config
Preparing to compile for kernel version 3.2.0
cd <your kernel dir>
./scripts/make_myconfig.pl
perl scripts/make_config_compat.pl /lib/modules/3.2.0-12-generic/build ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[2]: Entering directory `/home/andrew/Downloads/linux-tbs-drivers/v4l/firmware'
make[2]: Leaving directory `/home/andrew/Downloads/linux-tbs-drivers/v4l/firmware'
make -C firmware
CC ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/3.2.0-12-generic/build
make -C /lib/modules/3.2.0-12-generic/build SUBDIRS=/home/andrew/Downloads/linux-tbs-drivers/v4l modules
make[2]: Entering directory `/usr/src/linux-headers-3.2.0-12-generic'
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/au0828-core.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/au0828-i2c.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/au0828-cards.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/au0828-dvb.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/au0828-video.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/au0828-vbi.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/au8522_dig.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/au8522_decoder.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop-pci.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop-usb.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop-fe-tuner.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop-i2c.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop-sram.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop-eeprom.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop-misc.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop-hw-filter.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/flexcop-dma.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/bttv-driver.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/bttv-cards.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/bttv-if.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/bttv-risc.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/bttv-vbi.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/bttv-i2c.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/bttv-gpio.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/bttv-input.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/bttv-audio-hook.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/cafe-driver.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/mcam-core.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_v4l.o
CC [M] /home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_usb.o
/home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_usb.c:70:1: warning: data definition has no type or storage class [enabled by default]
/home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_usb.c:70:1: warning: type defaults to 'int' in declaration of 'MODULE_DEVICE_TABLE' [-Wimplicit-int]
/home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_usb.c:70:1: warning: parameter names (without types) in function declaration [enabled by default]
/home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_usb.c: In function 'cpia2_usb_init':
/home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_usb.c:902:9: error: 'THIS_MODULE' undeclared (first use in this function)
/home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_usb.c:902:9: note: each undeclared identifier is reported only once for each function it appears in
/home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_usb.c:903:1: warning: control reaches end of non-void function [-Wreturn-type]
make[3]: *** [/home/andrew/Downloads/linux-tbs-drivers/v4l/cpia2_usb.o] Error 1
make[2]: *** [_module_/home/andrew/Downloads/linux-tbs-drivers/v4l] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-3.2.0-12-generic'
make: *** [all] Error 2
ferni
Postby SergioDanielG » Tue Jan 31, 2012 7:00 pm
ferni Wrote:...
Hi ferni. I sent a email to support@tbsdtv.com two days ago with the same error. They say me they are working to update drivers, but it's not simple.
We can only hope.
Best regards.
SergioDanielG
Postby ferni » Wed Feb 01, 2012 10:02 am
SergioDanielG Wrote:Hi ferni. I sent a email to support@tbsdtv.com two days ago with the same error. They say me they are working to update drivers, but it's not simple.
We can only hope.
Best regards.
Thanks. Do you (or anyone else) know what is causing problems? Is it the new 3.2 kernel? If i go back to an old kernel will it work? Or is it an x64 problem?
ferni
Postby SergioDanielG » Wed Feb 01, 2012 7:04 pm
ferni Wrote:Thanks. Do you (or anyone else) know what is causing problems? Is it the new 3.2 kernel? If i go back to an old kernel will it work? Or is it an x64 problem?
It's the new 3.2 kernel. I don't know why. I'm actually using driever 20111118 with kernel 3.1.0-1 without problems..
Best regards.
SergioDanielG
Postby ferni » Thu Feb 02, 2012 5:20 am
Best regards.
Thanks - I found out the same thing last night - Installed ubuntu 11.10 x64 fresh and used the out of the box kernel and it compiled fine.
ferni
