Cannot record 2 streams at the same time - tbsviewer
Postby digitalgain » Wed Oct 12, 2011 8:46 pm
Just purchased a tbs6280 DVB-T2 Dual Tuner - PCI-E version.
Install was fine (used the updated v 1.0.0.6 drivers and the latest version of tbsviewer.
the scan picked up every channel (currently only receive SD till Nov 23rd when HD comes online)
Everything is working fine except one thing.
If i set 2 recordings in tbsviewer (for the same time on different channels) the recording shows as red in the recorder window and subsequently does not record.
How do i get tbsviewer to record off both tuners at the same time?
Apart from this small problem i am more than happy with the card so far, and even tbsviewer is ok.
Any help would be appreciated :)
digitalgain
Re: Cannot record 2 streams at the same time - tbsviewer
Postby digitalgain » Thu Oct 13, 2011 8:33 pm
Ignore my above post:
Using Media Centre on Win7 Ultimate 64 bit i am able to record 2 streams on different multiplexes at the same time.
I hate Media Centre so i purchased DVBViewer Pro and i now have everything set up perfectly :)
I am more than happy with my TBS 6280 purchase! :)
Only another 6 weeks till the DSO brings me Freeview HD in the UK :)
digitalgain
