TBS 6981 Crashes Windows 7 64-bit
Postby Spheron » Wed Dec 29, 2010 8:09 am
Hello @ all,
i tried to bring a TBS 6981 at Windows 7 64-bit to work but every time a made a channel scan windows is crashing down.
Tryed the channel scan in Windows Media Center, TBS Viewer and DVB Dream, every time Windows is crashing. For install i used the 2.0.0.5 and the 2.0.0.14 driver version.
I searched around i found the info that some mainboard not compatibel with the TBS 6981. I'm using the Zotac IONITX-F-E. Is this board compatibel? Are there any workarounds for this problem?
Greets
Marco
Spheron
Re: TBS 6981 Crashes Windows 7 64-bit
Postby cody » Wed Jan 05, 2011 6:04 am
hi Marco,
it's possible that there is some compatibility issue with your motherboard. i want to ask you to do the following test: unplug any cables from LNB inputs and try to scan again - of course scan won't give any channels, because the cables are disconnected, but it's just for a test. also, did you try to use external power plug on TBS 6981 to supply more power to the card?
thank you,
Postby coolumbo » Sat Jan 22, 2011 6:44 am
Hi Marco,
and everyone who has similar instability issues with Zotac mainboards(IONITX-F-E).
You need to install a more powerfull power-supply, this will solve this issue.
Regards
coolumbo
Postby cody » Sat Jan 22, 2011 8:49 am
coolumbo Wrote:everyone who has similar instability issues with Zotac mainboards(IONITX-F-E).
how much exaclty more powerful according to your experience in practice? thanks!
