no function with... UEFI
Postby saurepommes » Mon Oct 10, 2011 5:35 am
It really surprised me I couldn't run my TBS8921 after changing my motherboard. After 2 days of search I discovered my card will only do the job if it is installed on a MBR-partition, GPT (you need for UEFI) doesn't work at the moment. I did several tests and there is no doubt!
Is this problem known and a solution available? Or is this a problem with my special board?
(Asus P8H67-V, Intel i3 2100, W7 64-bit)
saurepommes
Re: no function with... UEFI
Postby steven » Wed Oct 12, 2011 11:25 am
Hi saurepommes
in GPT,The problem is can not get lock or can not detect the TBS8921 hardware?
Postby saurepommes » Mon Dec 12, 2011 6:42 pm
I use DVB-Viewer. It detects the driver of the card but I think it doesn't find the signal. (neither EPG)
saurepommes
Postby saurepommes » Thu Dec 29, 2011 10:37 pm
I've bought a new motherboard (Asrock z68 Pro3) and now the card doesn't work at all, no matter what I try. I would say it is broken if it didn't work with the last mb (see above)...
I'm really sick of spending my whole time and still nothing works! Any idea? If not I will have to buy a non TBS product :(
saurepommes
Postby saurepommes » Fri Dec 30, 2011 5:58 am
What is TS Capture? It says no driver is installed...
saurepommes
Postby smile » Sat Dec 31, 2011 9:20 am
TS capture,it is to get TS stream. it does not need driver.
smile
Postby AndersKM » Mon May 14, 2012 2:03 pm
Hallo!
I have the same problem .......ASUS P8Z68 DELUXE Motherboard and 2600K processor 16 Gb of ram Win 7 ultimate X64............
The card gets detected and drivers gets loaded ok BUT NO LOCK DURING SCAN...... :(
The card functions ok in another non UEFI machine same dish and cable.
Any solution...........is it a driver problem or hardware problem ????
Please find a solution.......
Thanks in advance.
AndersKM
Postby steven » Mon May 14, 2012 3:20 pm
Hi AndersKM
Would you mind having a update about ASUS P8Z68 DELUXE Motherboard's BIOS,
maybe it is the compatiable problem.
Postby AndersKM » Wed May 16, 2012 2:27 am
Hi Steven !
Thank´s for your quick reply .........But no luck my ASUS P8Z68 DELUXE is running the latest Bios (to my knowledge) 3304 I have previus tried 3203 and 0902 and both PCI slots .........the card works ok in ASUS P5Q Deluxe (No UEFI) 8Gb of ram on the same dish and cable.....and W7X64 Ultimate........
Question remains is it a driver or hardware problem UEFI / GPT ??????
Will TDS8922 have the same problem ????
On my ASUS P8Z68 DELUXE i have tried TBS6921 , TBS6925 (PCI-E) AND Hauppauge HVR-1300 (PCI) and they work ok ...........
Keep up the good work.......
AndersKM
Postby AndersKM » Fri May 25, 2012 1:46 pm
Hi!
Have You given up on this card ?????
/Anders
AndersKM
