TBS 8920 works fine in windows xp sp3 but problems in sp2
Postby aimanali » Sun Dec 26, 2010 4:00 am
sir CODY, TBS card is perfect for windows xp service pack 3 and Windows 7 but crashes with dvbdream in old windows xp service pack 2
aimanali
Works fine
Postby aimanali » Mon Dec 27, 2010 12:27 pm
The card works perfect on windows XP Sp3 .. but has problems only in windows XP old service pack 2
aimanali
Re: TBS 8920 Crashes with Dvbdream and progdvb
Postby cody » Tue Dec 28, 2010 4:53 am
did you try to make clean installation of Windows XP and use different video/audio codecs in DVBDream. i don't know what else to recommend, because it seems like problem isolated to your computer.
TBS 8920 ..best card for windows 7 nd sp3
Postby aimanali » Tue Dec 28, 2010 11:03 pm
TBS 8920 is the best ever card i have used .and works perfect in windows Xp service pack 3 and windows 7
aimanali
No crashes
Postby aimanali » Wed Dec 29, 2010 9:29 pm
The card gets fine in Windows XP service pack 3... I am very happy with this card
aimanali
Postby steven » Mon Feb 07, 2011 8:36 pm
Do you have used the dvbdream v1.5e verison? does it ok?
Postby aimanali » Fri Jul 01, 2011 9:26 pm
yes its ok with dvbdream 1.5 e and 1.5 f and all versions
aimanali
Postby aimanali » Thu Aug 18, 2011 7:51 pm
i forgot to post here in right time .. The prob was with windows OS..The card works fine in windows Xp service pack 3 and in windows 7.. but it will always crash in windows xp sp 2 .. i was using windows xp sp2 version thats why all problems were there..the card works smooth in windows xp sp3 and win 7..sorry for posting it late...On the following link i discussed problem with REL and my problem solved.. There is no prob in card and it works fine with windows XP SP 3 and windows 7
check out last post of mine on the following link...
http://www.dvbdream.org/forum/viewtopic ... 78c5457d89
SO .. my prob Solved/.!
aimanali
