Windows doesn't found card
Postby Sargot » Mon Oct 03, 2011 12:20 am
because my old gpu was broke i have buy a new therefore the new was bigger than i have plug the card from the PCIe 1x to a PCIe 8x but now Windows doesn't recognize the card
i take the card off start again shutdown plugin start again search for new hardware but still the same....
I use Win 7 Ultimate 64 bit
Sargot
Re: Windows doesn't found card
Postby steven » Sun Oct 09, 2011 10:17 am
Hi Sargot
Would you mind replug TBS6920 to PCIe 1x,if it is ok,i think it maybe your PCIe 8x slot problem.
Postby Sargot » Sat Dec 03, 2011 6:40 pm
Sry for my very late reply i solve the problem while using linux o.O
so my mainboard and card are okay but why Windows is not able anymore
to use the card is a mystery for me...
If check under Sound Video and GameController there is nothink related to this card i have even now no Idea....
P.S. there is no posibility to change back the slots are blocked from my GPU
Sargot
Postby adricha » Tue Jan 03, 2012 9:42 pm
I appear to be having the same problem.
My motherboard is a Gigabyte GA-H55M-S2H and only has 2 PCI-e slots on it. I am using the onboard graphics on Intel Core i3 processor so no separate graphics card. I have a DVB-T2 card in one slot for terrestrial tv and wanted to add this card in for the extra DVB-S2 channels. However, card does not seem to be happy and is just not seen by windows even with all appropriate drivers installed.
I am wondering if there is something clever I need to do to make sure both slots are enabled for non-graphics card purposes???
Cheers
A
adricha
