modulation 6 is not supported
Postby Phoenix1833 » Sun Sep 25, 2011 3:56 am
We use the TBS 6984.
When the produce scan-s2 in DVB-S2 (8QPSK), the card does not lock and get the following dmesg:
[ 237.936495] TurboSight TBS 6984 Frontend:
[ 237.936496] tbs6984fe - modulation 6 is not supported
driver last
Phoenix1833
Re: modulation 6 is not supported
Postby steven » Mon Sep 26, 2011 10:04 am
Would you mind tell us which parameter you are use to lock S2-8PSK TP.because if you use wrong parameter you can lock S2 TP.
Postby tombgp » Tue Nov 15, 2011 5:19 am
Getting the same error here,
root@dvb-s#:~/tbs/scan-s2# scan-s2 -t1 dvb-s/AMC1-103w
API major 5, minor 3
scanning dvb-s/AMC1-103w
initial transponder DVB-S  11760000 H 26670000 AUTO AUTO AUTO
initial transponder DVB-S2 11760000 H 26670000 AUTO AUTO AUTO
initial transponder DVB-S  11828000 V 5789000 AUTO AUTO AUTO
initial transponder DVB-S2 11828000 V 5789000 AUTO AUTO AUTO
>>> tune to: 11760:hS0:S0.0W:26670:
DVB-S IF freq is 1160000
WARNING: >>> tuning failed!!!
>>> tune to: 11760:hS0:S0.0W:26670: (tuning failed)
----------------------------------> Using DVB-S2
>>> tune to: 11760:hS1:S0.0W:26670:
>>> tune to: 11760:hS1:S0.0W:26670: (tuning failed)
>>> tune to: 11828:vS0:S0.0W:5789:
DVB-S IF freq is 1228000
>>> tune to: 11828:vS0:S0.0W:5789: (tuning failed)
>>> tune to: 11828:vS1:S0.0W:5789:
>>> tune to: 11828:vS1:S0.0W:5789: (tuning failed)
dmesg/kernel log:
Nov 14 15:15:01 dvb-s kernel: [14467.634854] TurboSight TBS 6984 Frontend:
Nov 14 15:15:01 dvb-s kernel: [14467.634856]  tbs6984fe - modulation 6 is not supported
Nov 14 15:15:04 dvb-s kernel: [14470.470748] TurboSight TBS 6984 Frontend:
Nov 14 15:15:04 dvb-s kernel: [14470.470750]  tbs6984fe - modulation 6 is not supported
Nov 14 15:15:07 dvb-s kernel: [14473.338546] TurboSight TBS 6984 Frontend:
Nov 14 15:15:07 dvb-s kernel: [14473.338548]  tbs6984fe - modulation 6 is not supported
Nov 14 15:15:10 dvb-s kernel: [14476.206343] TurboSight TBS 6984 Frontend:
Nov 14 15:15:10 dvb-s kernel: [14476.206345]  tbs6984fe - modulation 6 is not supported
root@dvb-s:~/tbs/scan-s2# lsmod | grep tbs
tbs6984fe              75213  4
saa716x_tbs_dvb        28597  0
tbs6928fe              17521  1 saa716x_tbs_dvb
tbs6922fe              17837  1 saa716x_tbs_dvb
saa716x_core           48957  1 saa716x_tbs_dvb
i2c_algo_bit           13199  2 i915,saa716x_tbs_dvb
stv090x                53193  1 saa716x_tbs_dvb
dvb_core               89930  4 saa716x_tbs_dvb,saa716x_core,cx23885,videobuf_dvb
root@dvb-s:~/tbs/scan-s2# lsmod | grep cx
cx23885               134938  0
rc_core                25734  8 ir_lirc_codec,ir_mce_kbd_decoder,ir_sony_decoder,ir_jvc_decoder,ir_rc6_decoder,ir_rc5_decoder,ir_nec_decoder,cx23885
cx2341x                23603  1 cx23885
videobuf_dma_sg        18710  1 cx23885
videobuf_dvb           13820  1 cx23885
videobuf_core          25097  3 cx23885,videobuf_dma_sg,videobuf_dvb
v4l2_common            15793  2 cx23885,cx2341x
videodev               94355  3 cx23885,cx2341x,v4l2_common
btcx_risc              13400  1 cx23885
tveeprom               17009  1 cx23885
root@dvb-s:~/tbs/scan-s2# uname -a
Linux dvb-s 3.0.0-12-generic-pae #20-Ubuntu SMP Fri Oct 7 16:37:17 UTC 2011 i686 i686 i386 GNU/Linux
tombgp
Postby tombgp » Tue Nov 15, 2011 5:23 am
Additionally, I couldn't compile scan-s2:
root@dvb-s:~/tbs/scan-s2# make
gcc -I../linux-tbs-drivers/linux/include -c scan.c -o scan.o
In file included from scan.c:48:0:
atsc_psip_section.h:57:1: note: offset of packed bit-field ‘reserved2’ has changed in GCC 4.4
scan.c:52:2: error: #error scan-s2 requires Linux DVB driver API version 5.1!
make: *** [scan.o] Error 1
So i tweaked the scan.c:
#if DVB_API_VERSION != 5 || DVB_API_VERSION_MINOR != 1
to
#if DVB_API_VERSION != 5 && DVB_API_VERSION_MINOR < 1
And it compiled fine.
This may be related to the problem above,
I will be appreciated for any help in resolving this problem
Tom
tombgp
Postby SergioDanielG » Tue Nov 15, 2011 8:43 am
tombgp Wrote: dvb-s/AMC1-103w
TBS6984 haven't got blindscan hardware. Try to complete AUTO AUTO AUTO with real parameters
For example:
S1 11760000 H 26670000 7/8 35 QPSK
Best regards.
SergioDanielG
