Unable to build driver on Arch Linux with kernel 2.6.36.1
Postby hda » Thu Dec 09, 2010 3:05 am
I tried everything suggested in this forum.
The error I get is
# make
/bin/sh: /sbin/lsmod: No such file or directory
perl scripts/make_config_compat.pl /lib/modules/2.6.36-ARCH/build ./.myconfig ./config-compat.h
creating symbolic links...
make -C firmware prep
make[1]: Entering directory `/root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/firmware'
make[1]: Leaving directory `/root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/firmware'
make -C firmware
  CC  ihex2fw
Generating vicam/firmware.fw
Generating dabusb/firmware.fw
Kernel build directory is /lib/modules/2.6.36-ARCH/build
make -C /lib/modules/2.6.36-ARCH/build SUBDIRS=/root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l  modules
make[1]: Entering directory `/usr/src/linux-2.6.36-ARCH'
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tuner-xc2028.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tuner-simple.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tuner-types.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/mt20xx.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tda8290.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tea5767.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tea5761.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tda9887.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/tda827x.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/au0828-core.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/au0828-i2c.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/au0828-cards.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/au0828-dvb.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/au0828-video.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/au8522_dig.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/au8522_decoder.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop-pci.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop-usb.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop-fe-tuner.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop-i2c.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop-sram.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop-eeprom.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop-misc.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop-hw-filter.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/flexcop-dma.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/bttv-driver.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/bttv-cards.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/bttv-if.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/bttv-risc.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/bttv-vbi.o
  CC [M]  /root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/bttv-i2c.o
/root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/bttv-i2c.c: In function 'init_bttv_i2c_ir':
/root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/bttv-i2c.c:437:3: error: too few arguments to function 'i2c_new_probed_device'
include/linux/i2c.h:293:1: note: declared here
make[2]: *** [/root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l/bttv-i2c.o] Error 1
make[1]: *** [_module_/root/linux-s2api-tbs6980-1_20101024/linux-s2api-tbs6980_1/v4l] Error 2
make[1]: Leaving directory `/usr/src/linux-2.6.36-ARCH'
make: *** [default] Error 2
Afterwards I installed the LTS kernel 2.6.32 and it compiled fine. So I guess the question is when is support for 2.6.36 coming?
hda
Re: Unable to build driver on Arch Linux with kernel 2.6.36.
Postby cody » Fri Dec 24, 2010 5:42 am
correct, Linux kernel version 2.6.36 is currently not supported and providing support for it is scheduled for the time after we finish the development of Linux for our new products - the idea is to have Linux drivers for all of our products including the new one for Linux kernel versions up to 2.6.35 and then fix the compatibility problems for 2.6.36+ kernels.
Postby jackhill » Tue Feb 01, 2011 4:11 pm
cody Wrote:correct, Linux kernel version 2.6.36 is currently not supported and providing support for it is scheduled for the time after we finish the development of Linux for our new products - the idea is to have Linux drivers for all of our products including the new one for Linux kernel versions up to 2.6.35 and then fix the compatibility problems for 2.6.36+ kernels.
Hi cody.
Am I going to have any problems compiling on the 2.6.35 kernel? I specifically need to be on that kernel in order to get my Intel HD graphics card working.
jackhill
Postby cody » Thu Feb 03, 2011 7:40 am
hi, kernel 2.6.35 should be fine.
Postby AndyBurns » Mon Apr 18, 2011 10:12 pm
cody Wrote:the idea is to have Linux drivers for all of our products including the new one for Linux kernel versions up to 2.6.35 and then fix the compatibility problems for 2.6.36+ kernels.
Any news on releasing as fully GPL, cleaning up the code as necessary and pushing support to mainline?
I got fed-up waiting for open source drivers to be released and pushed to the upstream kernel, gave my card away and will not buy TBS again.
AndyBurns
