Good signal but cannot obtain lock
Postby ister » Sat Sep 24, 2011 4:35 am
I understand I should get status "LF" and indication "FE_HAS_LOCK" for singal 74% (like in similar topic) and I get:
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -a 1 -H -C 34 -c ../hotbird_szap-s2.conf "RAI2"
reading channels from file '../hotbird_szap-s2.conf'
zapping to 2 'RAI2':
sat 0, frequency 10992 MHz V, symbolrate 27500000, coderate 3/4, rolloff 0.35
vpid 0x0201, apid 0x028b, sid 0x2140
using '/dev/dvb/adapter1/frontend0' and '/dev/dvb/adapter1/demux0'
status 01 | signal  74% | snr   0% | ber 0 | unc 0 |
status 03 | signal  74% | snr   0% | ber 0 | unc 0 |
and
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -a 1 -H -c ../hotbird_szap-s2.conf "RTR"
zapping to 3 'RTR':
sat 0, frequency 11034 MHz V, symbolrate 27500000, coderate auto, rolloff 0.35
vpid 0x0334, apid 0x033e, sid 0x06ac
root@srv1:~/tbs-110818/szap-s2# cat ../hotbird_szap-s2.conf
RAI1:10992:v:0:27500:512:60:8511
RAI2:10992:v:0:27500:513:651:8512
RTR:11034:v:0:27500:820:830:1708
NI:10930:h:0:27500:512:650:7501
RIK:12111:v:0:27500:782:331:782
My current configuration is:
root@srv1:~/tbs-110818/szap-s2# uname -a
Linux srv1 2.6.38-11-server #50-Ubuntu SMP Mon Sep 12 21:34:27 UTC 2011 x86_64 x86_64 x86_64 GNU/Linux
root@srv1:~/tbs-110818/szap-s2# dmesg |grep cx23885
[    9.691151] cx23885 driver version 0.0.2 loaded
[    9.691193] cx23885 0000:06:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
[    9.691490] CORE cx23885[0]: subsystem: 6981:8888, board: TurboSight TBS 6981 [card=30,autodetected]
[    9.951574] Modules linked in: cx23885(+) cx2341x videobuf_dvb dvb_core bttv(+) v4l2_common videodev v4l1_compat v4l2_compat_ioctl32 nouveau(+) videobuf_dma_sg videobuf_core ir_common ir_core btcx_risc ttm shpchp tveeprom drm_kms_helper drm i2c_algo_bit video x38_edac asus_atk0110 edac_core lp parport raid10 raid456 async_pq async_xor usbhid(+) xor async_memcpy async_raid6_recov hid pata_marvell floppy skge ahci libahci sky2 raid6_pq async_tx raid1 raid0 multipath linear
[   10.492116] cx25840 2-0044: cx23885 A/V decoder found @ 0x88 (cx23885[0])
[   11.279967] cx25840 2-0044: loaded v4l-cx23885-avcore-01.fw firmware (16382 bytes)
[   11.288817] cx23885_dvb_register() allocating 1 frontend(s)
[   11.289015] cx23885[0]: cx23885 based dvb card
[   12.138683] DVB: registering new adapter (cx23885[0])
[   12.168148] cx23885_dvb_register() allocating 1 frontend(s)
[   12.168320] cx23885[0]: cx23885 based dvb card
[   12.340081] DVB: registering new adapter (cx23885[0])
[   12.369570] cx23885_dev_checkrevision() Hardware revision = 0xa5
[   12.369757] cx23885[0]/0: found at 0000:06:00.0, rev: 4, irq: 19, latency: 0, mmio: 0xfe800000
[   12.370037] cx23885 0000:06:00.0: setting latency timer to 64
root@srv1:~/tbs-110818/szap-s2# modinfo tbs6981fe
filename:       /lib/modules/2.6.38-11-server/kernel/drivers/media/dvb/frontends/tbs6981fe.ko
license:        TurboSight Proprietary: www.tbsdtv.com
author:         Konstantin Dimitrov <kosio.dimitrov@gmail.com>
description:    TurboSight TBS 6981 Dual DVBS/S2 frontend driver module
depends:
vermagic:       2.6.38-11-server SMP mod_unload modversions
Please provide some advice, I have spent considerable time trying to find out what is wrong.
The adapter is working fine in a different PC with Win7 and connected to Diseqc. For the above tests I disconnected the Diseqc to reduce the elements that may be faulty.
Regards
ister
Re: Good signal but cannot obtain lock
Postby SergioDanielG » Sat Sep 24, 2011 6:01 am
sure that fec parameter is correct? For example, in www.satbeams.com the fec parameter for TP 10992 V 27600 es 2/3 and you are using './szap-s2 -a 1 -H -C 34 -c ../hotbird_szap-s2.conf "RAI2"'.
And what about scan this tp: 10992000 V 27500 AUTO AUTO AUTO with scan-s2 ?
Other question... Do you have more than 1 dvb card in your pc? or do you use diseqc switch?
Best regards.
SergioDanielG
Postby SergioDanielG » Sat Sep 24, 2011 6:10 am
I'm sorry, 6981 is dual tuner... But your system identify it as two adapters or as two frontends?
You can see that with
# ls -l -R /dev/dvb/
Best regards.
SergioDanielG
Postby ister » Sat Sep 24, 2011 3:33 pm
Hello SergioDanielG,
Thank you for your feedback. The TBS6981 driver delivers two adapters
root@srv1:~/tbs-110818# ls -l -R /dev/dvb/
/dev/dvb/:
total 0
drwxr-xr-x 2 root root 120 2011-09-23 22:54 adapter0
drwxr-xr-x 2 root root 120 2011-09-23 22:54 adapter1
/dev/dvb/adapter0:
total 0
crw-rw---- 1 root video 212, 1 2011-09-23 22:54 demux0
crw-rw---- 1 root video 212, 2 2011-09-23 22:54 dvr0
crw-rw---- 1 root video 212, 0 2011-09-23 22:54 frontend0
crw-rw---- 1 root video 212, 3 2011-09-23 22:54 net0
/dev/dvb/adapter1:
total 0
crw-rw---- 1 root video 212, 5 2011-09-23 22:54 demux0
crw-rw---- 1 root video 212, 6 2011-09-23 22:54 dvr0
crw-rw---- 1 root video 212, 4 2011-09-23 22:54 frontend0
crw-rw---- 1 root video 212, 7 2011-09-23 22:54 net0
The TBS6981 adapter port “LNB1” is connected to one LNB pointing to Hotbird 13E0 (no switch is installed). The LNB is dual, the other output is connected to sat box, that can receive RAI1, RAI2 and RTR without a problem.
RAI1, RAI2, RTR are in http://www.lyngsat.com/hb6.html as shown in attached images therefore the following seem correct:
RAI1:10992:v:0:27500:512:650:8511
(RAI has 2/3 and RTR has 3/4 – I did a mistake in previous post). Also I have cross checked these values with the values shown in sat box.
The output I get is:
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RAI1" -S 0 -C 23 -H -a 1
zapping to 1 'RAI1':
sat 0, frequency 10992 MHz V, symbolrate 27500000, coderate 2/3, rolloff 0.35
vpid 0x0200, apid 0x028a, sid 0x213f
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RAI2" -S 0 -C 23 -H -a 1
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RTR" -S 0 -C 34 -H -a 1
zapping to 3 'RTR':
sat 0, frequency 11034 MHz V, symbolrate 27500000, coderate 3/4, rolloff 0.35
Also scan-s2 provides me nothing but failures:
root@srv1:~/tbs-110818/scan-s2# ./scan-s2 -a 1 -q /usr/share/dvb/dvb-s/Hotbird-13.0E
API major 5, minor 1
>>> tune to: 12539:hC34S0:S0.0W:27500:
WARNING: >>> tuning failed!!!
>>> tune to: 12539:hC34S0:S0.0W:27500: (tuning failed)
>>> tune to: 12539:hC34S1:S0.0W:27500:
>>> tune to: 12539:hC34S1:S0.0W:27500: (tuning failed)
>>> tune to: 10719:vC34S0:S0.0W:27500:
>>> tune to: 10719:vC34S0:S0.0W:27500: (tuning failed)
>>> tune to: 10719:vC34S1:S0.0W:27500:
>>> tune to: 10719:vC34S1:S0.0W:27500: (tuning failed)
>>> tune to: 10723:hC34S0:S0.0W:29900:
>>> tune to: 10723:hC34S0:S0.0W:29900: (tuning failed)
>>> tune to: 10723:hC34S1:S0.0W:29900:
>>> tune to: 10723:hC34S1:S0.0W:29900: (tuning failed)
>>> tune to: 10757:vC34S0:S0.0W:27500:
>>> tune to: 10757:vC34S0:S0.0W:27500: (tuning failed)
>>> tune to: 10757:vC34S1:S0.0W:27500:
>>> tune to: 10757:vC34S1:S0.0W:27500: (tuning failed)
>>> tune to: 10775:hC34S0:S0.0W:28000:
>>> tune to: 10775:hC34S0:S0.0W:28000: (tuning failed)
>>> tune to: 10775:hC34S1:S0.0W:28000:
>>> tune to: 10775:hC34S1:S0.0W:28000: (tuning failed)
>>> tune to: 10795:vC34S0:S0.0W:27500:
>>> tune to: 10795:vC34S0:S0.0W:27500: (tuning failed)
Any advice is appreciated
Thank you,
Lyngsat section for RTR
Lyngsat section for RAI
ister
Postby SergioDanielG » Sat Sep 24, 2011 8:05 pm
Try adding lnb and frontend parameters
-l lnb-type (DVB-S Only) (use -l help to print types) or
-l low[,high[,switch]] in Mhz
-f number : use given frontend (default 0)
To be sure as you are using the correc frontend , do a simbolic link.
# ln -s /dev/dvb/adapter1/frontend0 /dev/dvb/adapter1/frontend1
and then
$ ./szap-s2 -c ../hotbird_szap-s2.conf "RAI1" -S 0 -C 23 -H -a 1 -f 1
I remember a similar problem. I have 2 cards but same configuration, 2 adapters. I don't remember how correct it... and I'm not in Hotbird foot print to check it...
Best regards
SergioDanielG
Postby ister » Sat Sep 24, 2011 9:39 pm
I reconnected cables and rebooted server. Then run the commands you instructed:
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RAI1" -S 0 -C 23 -H -a 1 -f 0 -l UNIVERSAL
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RAI1" -S 0 -C 23 -H -a 1 -f 0 -l DBS
FE_SET_PROPERTY failed: Invalid argument
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RAI1" -S 0 -C 23 -H -a 1 -f 0 -l STANDARD
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RAI1" -S 0 -C 23 -H -a 1 -f 0 -l ENHANCED
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RAI1" -S 0 -C 23 -H -a 1 -f 0 -l C-BAND
Here I receive error message “FE_SET_PROPERTY failed: Invalid argument“
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RAI1" -S 0 -C 23 -H -a 1 -f 0 -l 3700,12700
root@srv1:~/tbs-110818/szap-s2# ./szap-s2 -c ../hotbird_szap-s2.conf "RAI1" -S 0 -C 23 -H -a 1 -f 0 -l 10700,12700
I have also bttv devices (without a tunner) in the same server, could this be a reason for any conflict? The options I set are:
root@srv1:~/tbs-110818/szap-s2# cat /etc/modprobe.d/bttv.conf
options i2c-algo-bit bit_test=1
options bttv gbuffers=16 card=102,102,102,102,102,102,102,102 radio=0,0,0,0,0,0,0,0 tuner=4,4,4,4,4,4,4,4 chroma_agc=1 combfilter=2 full_luma_range=1 coring=1 autoload=0
Regards
ister
Postby ister » Mon Sep 26, 2011 12:22 am
I have blacklisted bttv and used default settings for modules i2c-algo-bit and tvaudio. No success.
I have recompiled the latest drivers using make clean, make distclean, make rminstall and then ./v4l/tbs-x86_64.sh, make, make install and reboot. No again success.
I have changed the cable and now it is using a different LNB (different brand/make) and it is pointing to Astra 19E2. No success again.
./szap-s2 -c ../astra_szap-s2.conf -S 0 -a 1 -f 0 -H "BBC" gives me signal 74% and does not lock. The file ../astra_szap-s2.conf is the one included with the drivers.
I do not understand why the signal is again 74%, the new LNB is more in the center of the satellite dish and I am better located in the footprint of Astra 19E2 (Athens, Greece).
My first LNB is "inverto rt" 0.2db.
Any advice is appreciated, I have run out of ideas.
ister
Postby ister » Tue Sep 27, 2011 3:45 am
All abovementioned builds are using the latest driver (2011/08/18).
I thought of trying the instructions at http://blog.mohammadzadeh.info/index.ph ... e-tbs-6980 for building the module. The build procedure is successful, the module loads but still no lock can be obtained.
The above instructions build the module release on 2010/10/24. Both drivers give me the same software version:
dmesg | grep tbs6981fe
[   11.112385] tbs6981fe: module license 'TurboSight Proprietary' taints kernel.
[   38.447127] tbs6981fe: software version is 1.95
and
dmesg | grep cx
[    9.503099] cx23885 driver version 0.0.2 loaded
Is this normal or I am not building/installing something correctly?
Regards,
ister
Postby ister » Wed Sep 28, 2011 2:02 am
After installing and uninstalling different driver versions and different patches I found on the internet I always had failure. No lock could be achieved.
Then I installed the latest driver again and tried adapter port LNB2 (adapter0). Success.
I do not understand, is my adapter port 1 faulty?
ister
Postby sami8519 » Fri Sep 30, 2011 12:18 am
Did you try these steps( I am not a tbs agent; maybe they have vanished)
1- Using both LNB! and LNB2 at the same time?
2-Using the power cable the comes inside the box?
Hope you solve your problem and if not then return it back to them as the support of tbs products is poor.
sami8519
