dvbdream bsod
dvbdream bsod
Postby Xtreme » Tue Sep 20, 2011 2:34 am
tips from user 0935
To solve the problem, Just open Dvbdream and go to: option/ preferences/performance then check the "delay for stability while channel changing" and set it to at least 500 ms or more. The more "ms" the better stability and the more time on channel changing.
There is an option on Progdvb too. called "speed of channel changing" just set it to slow.
Hope this help.
When i change some random channels with dvbdream i get blue screen error and restart.
I am using the latest driver for 8920 and latest dvbdream on tbsdtv.com.
I think its driver issue and my tbs 8920 is v20.
Ive attached the crash dumps for analyzes.
dump.rar
(54.24 KiB) Downloaded 566 times
Xtreme
Re: dvbdream bsod
Postby steven » Tue Sep 20, 2011 8:54 am
Hi Xtreme
What about other player like TBSView or ProgDVB,and is the channel is DVB-S or DVB-S2?
and would you mind tell us which sat and TP you are using?
Re: dvbdream bsod
Postby Xtreme » Tue Sep 20, 2011 11:27 am
I tried all of them but i get blue screen when changing channels even sometimes when i start tbs ip i get bluescreen scanning or changing channels in windows 7 mediacenter cause blue screen too.
I have this problem only in windows and i tried windows 7 and xp no difference and i think its driver issue no problem in Linux.
Xtreme
Re: dvbdream bsod
Postby steven » Tue Sep 20, 2011 5:34 pm
Hi Xtreme
if linux ok so please do not worry about this problem,we will solve it .
Do you changed channel between H and V ?and would you mind tell us the detail sat and TP you are using and whihc TP you are changing?
we will use this to test.
Re: dvbdream bsod
Postby 0935 » Sat Feb 20, 2016 12:29 am
Hi.
I know this topic is old but I had this problem too.
Hope this help.
0935
Re: dvbdream bsod
Postby steven » Sat Feb 20, 2016 5:28 pm
0935 Wrote:Hi.
Hope this help.
Thanks for share this way we will let your post on the top let more people know this.
Kind regards
