Is there A CI card for this dvb-s2 card?
Postby kjeb » Sun Sep 18, 2011 5:45 am
I'm thinking about buying this tv card, but need a CI for my conax cam.
Is there a CI card made for thise tv card?
-Kjell
kjeb
Re: Is there A CI card for this dvb-s2 card?
Postby steven » Sun Sep 18, 2011 8:34 am
the TBS 5980 and TBS 6928 are dvb-s2 cards with CI :D
Postby alrehman » Mon May 21, 2012 6:16 pm
can i connect CI for conax cam with tbs6984
alrehman
Postby smile » Mon May 21, 2012 6:39 pm
Hi alrehman
The TBS6984 card without CI .it has not CI socket .this is the TBS6984 product presentation http://www.tbsdtv.com/products/tbs6984-dvb-s2-quad-tuner-pcie-card.html .
if you want the card with CI,you can select TBS 5980 , TBS 6928 or TBS 6991. http://www.tbsdtv.com/products/,you can find their product presentation in this URL.
Thanks!!!
smile
