I received the product, I use it on openSuSE linux 11.4, kernel 2.6.37
I compiled and linked the code, no problems.
It works fine for unencrypted channels, both SD and HD dvb-s and dvb-s2
I use kaffeine and have astra 1, astra 2 and astra 3 sattelites
However, for encrypted transmissions, my mediaguard3 chipcard + certified
CAM does function only sometimes. ( I have legal card and CAM, paying for
it, no funny stuff !! ) the CAM is certified by Canal Digitaal, provider
in most of europe and works fine with inverto scena 5m sat receiver.
It seems to be an overflow in the software...
Please look at the excerpt below from dmesg, and specifically the last 3
lines.
It is a buffer overflow, apparently.
In first instance I do get picture + sound from crypted Netherlands HD
channel 1,
works fine.
If I change to other encrypted channel, it mostly fails with message as
below, but not always.
After failure of encrypted channel, Unencrypted SD and HD still works , no
problems with that. Once encrypted fails, it does not recover when
changing to other encrypted channel that worked before failure......
Please fix this problem, otherwise very good product.
I am willing to do some testing, if you tell me what to do.
hope to hear from you soon,
regards
rensg
_______________________________________________________
=>grep -i -e dvb -e usb dmesg.txt
[ 0.326644] usbcore: registered new interface driver usbfs
[ 0.326644] usbcore: registered new interface driver hub
[ 0.326644] usbcore: registered new device driver usb
[ 2.205590] input: Logitech HID compliant keyboard as
/devices/pci0000:00/0000:00:02.1/usb1/1-3/1-3.4/1-3.4:1.1/input/input2
[ 2.205650] generic-usb 0003:046D:C30E.0002: input,hidraw1: USB HID
v1.10 Device [Logitech HID compliant keyboard] on
usb-0000:00:02.1-3.4/input1
[ 6.992052] bttv0: add subdevice "dvb0"
[ 7.149274] bt878_probe: card id=[0x1c11bd],[ Pinnacle PCTV Sat ] has
DVB functions.
[ 7.173699] DVB: registering new adapter (bttv0)
[ 7.248930] DVB: registering adapter 0 frontend 0 (Conexant CX24110
DVB-S)...
[ 7.729939] dvb-usb: found a 'TBS Qbox DVB-S2 CI USB2.0' in cold state,
will try to load a firmware
[ 7.920499] dvb-usb: downloading firmware from file
'dvb-usb-tbsqbox-id5980.fw'
[ 8.039028] dvb-usb: found a 'TBS Qbox DVB-S2 CI USB2.0' in warm state.
[ 8.039088] dvb-usb: will pass the complete MPEG2 transport stream to
the software demuxer.
[ 8.039232] DVB: registering new adapter (TBS Qbox DVB-S2 CI USB2.0)
[ 8.258195] dvb-usb: MAC address: 00:22:ab:c0:1c:58
[ 8.382933] DVB: registering adapter 1 frontend 0 (STV090x
Multistandard)...
[ 8.399872] input: IR-receiver inside an USB DVB receiver as
/devices/pci0000:00/0000:00:02.1/usb1/1-3/1-3.2/input/input6
[ 8.399933] dvb-usb: schedule remote query interval to 150 msecs.
[ 8.399937] dvb-usb: TBS Qbox DVB-S2 CI USB2.0 successfully initialized
and connected.
[ 8.399957] usbcore: registered new interface driver tbsqbox2ci
[ 16.243349] dvb_ca adapter 1: DVB CAM detected and initialised
successfully
[ 61.622940] dvb_ca adapter 1: DVB CAM detected and initialised
successfully
[ 87.184697] dvb_ca adapter 1: CAM tried to send a buffer larger than
the link buffer size (33228 > 254)!
[ 87.386397] dvb_ca adapter 1: DVB CAM link initialisation failed
2.6.37.6-0.7-desktop:root:gamez:[/root]
