ASUS E35M-1 Deluxe
ASUS E35M-1 Deluxe
Postby lbpvr » Tue Sep 13, 2011 2:32 pm
Anyone using this tuner card with this motherboard?
lbpvr
Re: ASUS E35M-1 Deluxe
Postby steven » Wed Sep 14, 2011 9:20 am
Hi lbpvr
We have not tested this mainboard ,but we have tested GA-E350N-USB3 which is like ASUS E35M-1 Deluxe,
wish this can help you.
Postby lbpvr » Wed Sep 14, 2011 2:56 pm
Did you have to connect the external power cable to the device to get it to work correctly? I am trying to resolve the issue that I have with mine following resume from sleep as it does not always tune. Could the card be faultly?
lbpvr
Postby steven » Thu Sep 15, 2011 9:45 am
lbpvr Wrote:Did you have to connect the external power cable to the device to get it to work correctly? I am trying to resolve the issue that I have with mine following resume from sleep as it does not always tune. Could the card be faultly?
You means that you can not resume from sleep ok every time?and when it can not tune try to lock once again is it ok?
and do you have updated your BIOS?
Postby lbpvr » Thu Sep 15, 2011 4:15 pm
That is correct except I have to re-launch the application twice following the failure before the device tunes correctly. My BIOS is at 1202 if that helps, the very latest.
lbpvr
Postby steven » Fri Sep 16, 2011 4:41 pm
I know this problem about you,but after install this driver:
http://hotfile.com/dl/128478711/1a027f6 ... e.rar.html
we test it ok now,so are you sure you are use the latest driver.
would you mind give me a picture of TBS6981's driver information in Device manage.
Postby lbpvr » Sat Sep 17, 2011 1:07 am
Please find attached dump.
Device manager view
lbpvr
