TBS6981 Install Problems under Mandriva
Postby fred01 » Sat Nov 06, 2010 8:44 am
I had no problems to build and install the driver (20101024) for TBS 6981.
However after restart I get the following message:
# dmesg | grep cx23885
cx23885 driver version 0.0.2 loaded
cx23885 0000:07:00.0: PCI INT A -> GSI 19 (level, low) -> IRQ 19
cx23885[0]: Your board isn't known (yet) to the driver.
cx23885[0]: Try to pick one of the existing card configs via
cx23885[0]: card=<n> insmod option. Updating to the latest
cx23885[0]: version might help as well.
cx23885[0]: Here is a list of valid choices for the card=<n> insmod option:
cx23885[0]: card=0 -> UNKNOWN/GENERIC
cx23885[0]: card=1 -> Hauppauge WinTV-HVR1800lp
cx23885[0]: card=2 -> Hauppauge WinTV-HVR1800
cx23885[0]: card=3 -> Hauppauge WinTV-HVR1250
cx23885[0]: card=4 -> DViCO FusionHDTV5 Express
cx23885[0]: card=5 -> Hauppauge WinTV-HVR1500Q
cx23885[0]: card=6 -> Hauppauge WinTV-HVR1500
cx23885[0]: card=7 -> Hauppauge WinTV-HVR1200
cx23885[0]: card=8 -> Hauppauge WinTV-HVR1700
cx23885[0]: card=9 -> Hauppauge WinTV-HVR1400
cx23885[0]: card=10 -> DViCO FusionHDTV7 Dual Express
cx23885[0]: card=11 -> DViCO FusionHDTV DVB-T Dual Express
cx23885[0]: card=12 -> Leadtek Winfast PxDVR3200 H
cx23885[0]: card=13 -> Compro VideoMate E650F
cx23885[0]: card=14 -> TurboSight TBS 6920
cx23885[0]: card=15 -> TeVii S470
cx23885[0]: card=16 -> DVBWorld DVB-S2 2005
cx23885[0]: card=17 -> NetUP Dual DVB-S2 CI
cx23885[0]: card=18 -> Hauppauge WinTV-HVR1270
cx23885[0]: card=19 -> Hauppauge WinTV-HVR1275
cx23885[0]: card=20 -> Hauppauge WinTV-HVR1255
cx23885[0]: card=21 -> Hauppauge WinTV-HVR1210
cx23885[0]: card=22 -> Mygica X8506 DMB-TH
cx23885[0]: card=23 -> Magic-Pro ProHDTV Extreme 2
cx23885[0]: card=24 -> Hauppauge WinTV-HVR1850
cx23885[0]: card=25 -> Compro VideoMate E800
cx23885[0]: card=26 -> Hauppauge WinTV-HVR1290
cx23885[0]: card=27 -> Mygica X8558 PRO DMB-TH
CORE cx23885[0]: subsystem: 6981:8888, board: UNKNOWN/GENERIC [card=0,autodetected]
cx23885_dev_checkrevision() Hardware revision = 0xa5
cx23885[0]/0: found at 0000:07:00.0, rev: 4, irq: 19, latency: 0, mmio: 0xfbc00000
cx23885 0000:07:00.0: setting latency timer to 64
IRQ 19/cx23885[0]: IRQF_DISABLED is not guaranteed on shared IRQs
Any suggestions? Thanks
fred01
Re: TBS6981 Install Problems under Mandriva
Postby cody » Mon Nov 08, 2010 3:40 am
what you get means that for some reason "cx23885.ko" that you built from driver "20101024" for TBS 6981 is not loaded in your kernel (or not installed), because "CORE cx23885[0]: subsystem: 6981:8888, board: UNKNOWN/GENERIC [card=0,autodetected]" indicates that the default "cx23885.ko" that comes with the kernel is loaded. did you update the kernel after you installed the driver, which could replace "cx23885.ko" with default one?
Postby fred01 » Tue Nov 09, 2010 3:54 am
No, I did not update/change the kernel. However, you got me on the right track - v4l was pre-installed with all the modules gziped. Thus, even though all modules got installed, it was still loading the .gz module. After deleting all .gz and running a depmod again, the module got loaded just fine. Thanks again!
fred01
Postby cody » Tue Nov 09, 2010 4:44 am
i guess that information will be of help to other Mandriva users too, thanks for sharing.
