Problem watching TV when no signal (solved)
Postby garry » Fri Sep 02, 2011 5:35 am
TBS6984 works very well until signal is good. When rain starts, the signal dissapears and as a result video stops. This is expected. But when the rain stops and the sun comes out, signal becomes good again - video does not appears. Moreover, when I reopen program for watching - also no video, no errors. The only way is to restart my computer, after that all works fine. Windows 7 x64.
Is it a problem with drivers?
Garry.
garry
Re: Problem watching TV when no signal
Postby steven » Fri Sep 02, 2011 9:46 am
When rain starts, the signal dissapears , do you have close the program or you just let the program on wait the rain stop.
and is this always occur when have rain?you can have a test just plug off the LNB and wait a few seconds then plug in the LNB ,if it is ok,
maybe it is not the rain problem.
wait for your test report.
Postby garry » Fri Sep 02, 2011 3:24 pm
Thank you for reply.
I do not close program and let the program on wait the rain stop. It always occur when the rain is strong enough for a long time so signal dissapears at all for a long time. If rain is not so strong, signal is not dissapears at all and I can watch TV with artefacts and interrups, and in this case when rain stops all is ok. Usually it occurs in such a way: at first I can watch TV with interrupts and at some moment (~10-15 minutes) TV stops at all. Once I waited then for a few hours, rain was long over - no effect. After that when I restarted my computer all works fine.
I do not use LNB at all, at the moment I use only one tuner (A), one transponder, and watch one channel. I tested in DTV Viewer from DirectShow.NET.
garry
Postby steven » Fri Sep 02, 2011 4:02 pm
Hi garry
Thanks for the information,would you mind try to use other view soft instead to have a test,like DVBDream or TBSView.
and we will have a test like you say,if have any progress we will contact you as soon as possible.
Postby garry » Fri Sep 02, 2011 4:28 pm
Ok, I also will test it in other programs and report the results.
garry
Postby steven » Mon Sep 05, 2011 9:20 am
Hi garry
Is the other player ok?
Postby garry » Mon Sep 05, 2011 2:56 pm
Hi, steven,
Last days there was no rain, so have not been able to test...
garry
Postby steven » Mon Sep 05, 2011 3:11 pm
garry Wrote:Hi, steven,
:D
Postby garry » Fri Sep 09, 2011 4:16 pm
Hi, steven,
Today I tested in TBSViewer - the same result. At first I watched TV with interrupts about 1 hour and then video stoped at all. When I closed TBSViewer after ~12 hours (when rain stoped) and restarted it - there was no video, just a black window. But when I restarted my computer all played ok.
So I think the problem is in drivers, is there any solution exists? I use last driver version - v1.0.1.3.
garry
Postby steven » Sat Sep 10, 2011 9:28 am
Hi garry
We will take a experiment like you said.If have any progress we will contact you as soon as possible. :)
