New Progress About No signal after resume from sleep
Postby steven » Wed Aug 31, 2011 3:12 pm
Hi All :D
Sorry for let you wait so long time about this problem,Now we have solved this problem ,please try the new driver,
here is the download linker:
http://hotfile.com/dl/128478711/1a027f6/20110831-driver-release.rar.html
Please use this to have a test ,and send a test report here.
Re: New Progress About No signal after resume from sleep
Postby UncleM1ch4el » Thu Sep 01, 2011 12:40 am
Just downloading now, many thx for new drivers. Hoping they fix the problem.
UncleM1ch4el
Postby steven » Thu Sep 01, 2011 11:08 am
UncleM1ch4el Wrote:Just downloading now, many thx for new drivers. Hoping they fix the problem.
wait for your test report. :D
Postby UncleM1ch4el » Sat Sep 03, 2011 10:40 pm
I have tested everyday since updated drivers and they work perfectly when resuming from sleep now which is excellent, many thx.
Another question but might night not be related to the tv card but changing channels can take about 20seconds upto half a minute or seems about that long but Im using Next PVR so it might be that not sure?
UncleM1ch4el
Postby steven » Mon Sep 05, 2011 9:25 am
Hi UncleM1ch4el
Do you change channels between S1 and S2 channel ?and would you mind tell us which sat and transponder you are use?
Postby lbpvr » Tue Sep 06, 2011 12:24 am
I have tried this and the problem persists. I have verfiied the driver as 2.0.0.21 31-AUG but following resume from sleep the tuner still fails to tune.
Is there an option to generate a debug log at all?
lbpvr
Postby steven » Tue Sep 06, 2011 10:36 am
lbpvr Wrote:I have tried this and the problem persists. I have verfiied the driver as 2.0.0.21 31-AUG but following resume from sleep the tuner still fails to tune.
Hi lbprv
Do you have used VirtualBox ,if you have ,please see this topic.
viewtopic.php?f=21&t=167&p=4783#p4783
Postby lbpvr » Thu Sep 08, 2011 1:46 am
No I have not. This is a very stock install of W7 64bit. The update does appear to be slightly better as it sometimes resumes from sleep ok. However, when you want a recording to occur and it does not it still makes it un-reliable and essentially still broken. Any way of debugging this?
lbpvr
Postby UncleM1ch4el » Mon Sep 12, 2011 9:11 pm
steven Wrote:Hi UncleM1ch4el
Hi, sorry for late reply been away. Anyway i live in the UK an get my channels from 28.2 Astra and yes I change channels between SD and DVBS2 channels such as Channel 4 HD and BBC 1 & BBC HD. They all work fine, but just a longish delay between changing channels using the Next PVR software.
UncleM1ch4el
Postby lbpvr » Tue Sep 13, 2011 2:30 pm
Following further tests with this card, I have also found that if I re-start dvbviewer after watching a DVB-S feed then it fails to tune and I have to re-start it a further two times before it then correctly tunes. This is probably what is happening when it tries to record which is why it is hit and miss. On a resume from sleep the device appears in device manager ok and it also says that it is working ok. Could these issues be a fault with the card or do I need to connect the external power cable? Has anyone else with an ASUS E35M-1 had similar issues? Any thoughts please before I end up getting rid of this card?
lbpvr
