No TV signal detected
Postby sdamaged99 » Tue Aug 30, 2011 7:02 pm
I have the 6981 card installed in my HTPC using Windows 7 Media Centre, and most of the channels work OK, except some of them say ““There is currently no TV signal detected for this channel. The channel may be temporarily off-the-air, or you may need to adjust or reconnect your TV antenna.”
Most of the channels work OK, but BBC HD, Channel 4 HD and some others just won’t seem to work.
The signal bars are full strength. I am using 28.2E Astra / Eurobird 1. I have a freesat HD box in my bedroom which receives all the channels fine so it’s not a satellite dish issue
My system specs are below
Intel Core i3 2100T
Gigabyte GA-H61M-S2V-B3 Motherboard
4GB OCZ Low Voltage RAM
OCZ Vertex 2SE 50GB SSD (OS)
600w Corsair HX600 PSU
500GB Western Digital Scorpio Blue HDD (Recorded TV)
ATI Radeon HD5570 HDMI
Asus Xonar HDAV1.3
Blu Ray Drive
TBS 6981 Dual DVB-S2 High Definition Digital Satellite Tuner
sdamaged99
Re: No TV signal detected
Postby bob » Tue Aug 30, 2011 7:25 pm
Please check this link:http://www.tbsdtv.com/forum/viewtopic.php?f=21&t=454
Maybe you need to update the TP list in your media center or scan the BBC HD manually.
bob
