driver won't compile for kernel version 3.0.0
Postby difei » Sat Aug 27, 2011 2:35 pm
Greetings all,
T_DIGITAL_TV undeclared. Any suggestions? Thanks In Advance.
# make -j3
make -C /usr/src/qboxs2/linux-tbs-sources/v4l
make[1]: Entering directory `/usr/src/qboxs2/linux-tbs-sources/v4l'
make -C firmware prep
creating symbolic links...
make[2]: Entering directory `/usr/src/qboxs2/linux-tbs-sources/v4l/firmware'
make[2]: Leaving directory `/usr/src/qboxs2/linux-tbs-sources/v4l/firmware'
make -C firmware
make[2]: Nothing to be done for `default'.
Kernel build directory is /lib/modules/3.0.0-1-amd64/build
make -C /lib/modules/3.0.0-1-amd64/build SUBDIRS=/usr/src/qboxs2/linux-tbs-sources/v4l CFLAGS="-I../linux/include -D__KERNEL__ -I/include -DEXPORT_SYMTAB" modules
make[2]: Entering directory `/usr/src/linux-headers-3.0.0-1-amd64'
  CC [M]  /usr/src/qboxs2/linux-tbs-sources/v4l/tuner-xc2028.o
  CC [M]  /usr/src/qboxs2/linux-tbs-sources/v4l/tda8290.o
  CC [M]  /usr/src/qboxs2/linux-tbs-sources/v4l/tea5767.o
/usr/src/qboxs2/linux-tbs-sources/v4l/tuner-xc2028.c: In function 'xc2028_set_params':
/usr/src/qboxs2/linux-tbs-sources/v4l/tuner-xc2028.c:1178:5: error: 'T_DIGITAL_TV' undeclared (first use in this function)
/usr/src/qboxs2/linux-tbs-sources/v4l/tuner-xc2028.c:1178:5: note: each undeclared identifier is reported only once for each function it appears in
/usr/src/qboxs2/linux-tbs-sources/v4l/tuner-xc2028.c:1179:1: warning: control reaches end of non-void function
make[5]: *** [/usr/src/qboxs2/linux-tbs-sources/v4l/tuner-xc2028.o] Error 1
make[5]: *** Waiting for unfinished jobs....
make[4]: *** [_module_/usr/src/qboxs2/linux-tbs-sources/v4l] Error 2
make[3]: *** [sub-make] Error 2
make[2]: *** [all] Error 2
make[2]: Leaving directory `/usr/src/linux-headers-3.0.0-1-amd64'
make[1]: Leaving directory `/usr/src/qboxs2/linux-tbs-sources/v4l'
make: *** [all] Error 2
Cheers,
Difei
difei
Re: driver won't compile for kernel version 3.0.0
Postby andyt12 » Sat Aug 27, 2011 7:12 pm
No it doesnt, a few changes are required.
I have updated it for 3.0 series kernel, I tried to upload it here a week or so ago but the forum would fail.
I will try again, keep an eye out for my post. QBOX S2 3.0 series driver.
andyt12
Postby difei » Mon Aug 29, 2011 11:15 am
Thanks, Andy.
difei
