problem withe Driver & IPdata
Postby M457 » Fri Aug 26, 2011 3:47 pm
hi
pls new driver and ipdata
Quality is very low
there are some 16apsk signal that i can not luck on them completely
can you do sth to improve the signal quality in your new driver and ipdata
M457
Re: problem withe Driver & IPdata
Postby steven » Fri Aug 26, 2011 3:51 pm
Next version we will update the signal value.
Postby sotos65 » Fri Aug 26, 2011 11:27 pm
Even better, scrap the quality percentage display (most of the times is a meaningless value, not comparable between two different dvb cards or a set-top decoder), and replace it with the SNR display in dB (at least in the TBS Recorder/TBS ipdata tools).
sotos65
Postby tales21 » Sat Aug 27, 2011 5:08 pm
Signal level is weak in Windows xp (not been update driver like win7 ???(25/8/2011))
please put update driver for win xp 32bit
tales21
Postby crazycat » Mon Aug 29, 2011 12:25 am
you can setup win7 driver on WinXP&Vista
i think separate WinXP driver build not need for SAA7160-based devices. RC VHID driver not used and Microsoft Diseqc BDA-extension can be presented in single driver build for XP,Vista,7.
Postby tales21 » Mon Aug 29, 2011 1:59 pm
Thank you very much Mr. crazycat
It worked very well
But still the problem of start-stop signals on some frequencies, especially on the scheduled 32apsk
thanks alot :mrgreen:
tales21
