TBS6920 not initialyze
Postby banka » Fri Oct 08, 2010 7:14 pm
my TBS6920 card has problem, after hang the computer and restarting the slot having card does not not initialize.
banka
banka
Re: TBS6920 not initialyze
Postby cody » Mon Oct 11, 2010 3:42 pm
hi, it sounds like your TBS 6920 card got burnt/faulty. did you try it in another computer too? if so, please, contact us on the supports e-mails ( euro_support@tbsdtv.com or support@tbsdtv.com - depends on where you're located ) to arrange the replacement under the warranty.
