driver server 2008 issue
Postby linux2003 » Fri Oct 08, 2010 6:14 am
Hello and not be tired of my 8920 driver Windows 7 will download from the site when I go to install Windows 2008 Server does not work please help .
thanks
linux2003
Re: driver server 2008 issue
Postby cody » Fri Oct 08, 2010 3:04 pm
it's not TBS driver fault, but Microsoft's - they removed BDA support for their Windows Server 2008 products (and so no any DVB card can work in such operating system), but there is a way to manually add it again:
http://www.msfn.org/board/topic/114549- ... 2a1ef6790e
it's not as easy as it looks to re-add BDA support to Windows 2008 though, but if you do it right all TBS DVB cards will work perfectly well in that operating system. however, you don't need TBS, but more Microsoft technical support in the case.
