tbs6980 started to show "no signal"
Postby dynamic » Sat Aug 20, 2011 7:12 am
I am using the tbs6980 card since begin of 2010 and so far quite satisfied - until today.
Today all of a sudden the card started to show "no signal" on a single channel ( Nick on Astra19.2 ), which my kids immediately discovered.
As I couldn't really figure out the reasons I thought to check my "Mediaportal" configuration and as I couldn't find anything obvious, I decided to reboot the system. Ever since I am receiving "no signal" on all channels.
In the meantime, I have upgraded the driver to 2.0.0.19 but no change. Re-installed DVBdream ( as this usually works without issues ) and tested - nothing!!
I am now wondering, whether the 6980 may have a problem - is there any tool that one could use to do a HW level check on health status of the tbs6980 ?
Everything else on the system ( Asrock A330ION,W7 Ultimate 64bit, 4GB RAM, Mediaportal ) appears to be running just fine.
I checked the signal from the LNB, which looks OK as another SAT-Receiver works without issues with the signal.
Can anyone help or give advise as to how one can locate the problem and detect if there are possible HW issues ?
Regards
dynamic
dynamic
Re: tbs6980 started to show "no signal"
Postby steven » Tue Aug 23, 2011 3:00 pm
Would you mind try this driver:
http://hotfile.com/dl/127593007/55c7623/TBS6980_win7_driver.rar.html
and give us your test report.
Postby dynamic » Thu Sep 01, 2011 3:10 pm
@Steven
Sorry not responding earlier ( was on a business trip ).
This looks to be the driver Version 2.0.0.19 ? That one I had already tried with no result.
I have in the meantime done many activities ( including a brand new installation from scratch, to exclude the possibility of a W7 upgrade messing up things ) and the card started to work INTERMITTENTLY. At the moment, it show signals from one LNB but is unable to switch to my second LNB.
Regards
dynamic
dynamic
Postby steven » Mon Sep 05, 2011 9:27 am
Hi dynamic
You mean that you first LNB is ok and the second is not ok?
Postby dynamic » Mon Sep 05, 2011 2:49 pm
Hi steven,
yes, I seem currently to have a problem with one LNB only. In the meantime I checked my LNBs and one seems to have "drawn water" during one of the recent storms we had here.
I have ordered two new LNBs now and currently waiting for delivery after which I will hopefully be able to tell what the issue was.
I am now wondering whether this may also have been the root cause for my initial problem, that one defective LNB could have had side effects avoiding tuning of the DVB-S2 card on any LNB and TP ?!
Will update once I have been able to put in the new LNBs.
THanks so far!
Regards
dynamic
dynamic
Postby steven » Tue Sep 06, 2011 2:59 pm
Hi dynamic
Is the new LNB ok?
