Tuner stopped working ?
Postby cjstephen » Fri Aug 19, 2011 11:00 pm
I took the aerial cable out temporarily and mistakenly booted without. Every since, with the aerial replaced, all I get is:
[ 12.732573] tbs62x0fe: tuner attach failed
[ 12.732682] TurboSight TBS 6280: frontend initialization failed
Reloading the respective modules or rebooting brings no change.
70db µV clear signal on aerial.
What's going on ?
Regards,
Colin
cjstephen
Re: Tuner stopped working ?
Postby steven » Wed Sep 21, 2011 2:35 pm
Hi cjstephen
is in windows ok?can you have a test in windows?
Postby cjstephen » Fri Sep 23, 2011 6:21 pm
It turned out that the card was faulty. Great support from TBS to diagnose the problem!
Once DABS finally supplied a replacement the new card worked straight away, including the newly switched over DVB-T2. Very pleased :)
Colin
cjstephen
