TBS5922 Issues (Solved)
Postby pennym » Fri Aug 19, 2011 9:01 am
I received my TBS5922 a few days ago and have 2 problems:-
1) Unable to blind scan Ku satellites when using Ku universal LNB settings (The LNB is a Ku universal LNB). Any results I get are approximately 850 Mhz to low.
example: Actual transponder is 12305 - Blind scan result is 11451 - I have fiddled with the Ku universal settings in Blindscan but cannot find a solution.
Blind scanning is OK when scanning my C-band dish.
2) I get irregular pixellation (anywhere from a couple of seconds apart to a minute apart) on both Ku and C band.
I do not have this problem with my Twinhan PCI card or my dreambox DM800 and I have tested this using different computers different cables and different satellite dishes and still the problem persists.
My computers are running Windows 7 32 bit and I am using your latest programs and drivers.
Any help will be appreciated.
pennym
Re: TBS5922 Issues
Postby steven » Fri Aug 19, 2011 2:20 pm
Hi pennym
For your first question,would you mind tell us your Blindscan setting's picture,are you sure that you are input the right value of LNB?
Re: TBS5922 Issues
Postby steven » Fri Aug 19, 2011 2:26 pm
and for your second question,would you mind give us more information like which sat and transponder you are use,and write an email to our support@tbsdtv.com,
we will give you an answer as soon as possible.
Re: TBS5922 Issues
Postby tempo » Sat Aug 20, 2011 3:58 am
pennym Wrote:Any results I get are approximately 850 Mhz to low.
850 MHz = 10600 - 9750 MHz. So when you scan high Ku band (11700-12750), the program thought that it is low Ku band (10700-11700).
Wrong LOF value used. Try 10600 MHz instead of 9750 MHz.
tempo
Re: TBS5922 Issues
Postby pennym » Sat Aug 20, 2011 7:46 am
I have tried setting the LOF to 10600 but the switch setting of 11700 does not seem to work and prevents scanning Ku high.
Attached are 2 pictures with my results using correct settings and modified LOF settings. The 3rd picture shows what should be there.
The satellite I am testing with is Optus C1/D3 at 156.0E.
pennym
Re: TBS5922 Issues
Postby pennym » Sun Aug 21, 2011 7:52 am
I need to make a correction to my previous posts.
The 850 Mhz variation I mentioned only happens when I piggy-back the TBS5922 off the dreambox and have the dreambox control the LNB.
I now think the only problem with blindscan and the TBS5922 has is that it will not scan Ku high with the universal LNB settings.
I have attached my blindscan results for the same satellite (Optus C1/D3) vertical transponders only having the dreambox contol the LNB. Sorry for providing mis-leading comments earlier but I think this maybe the CLUE as to what needs to be fixed in your blindscan program since I would have expected the same results (for vertcal only) no matter which device runs the LNB.
Dreambox controlling LNB
pennym
Re: TBS5922 Issues
Postby steven » Mon Aug 22, 2011 1:59 pm
if you use high Ku band,please choose 22k on.
thanks
Re: TBS5922 Issues
Postby pennym » Tue Aug 23, 2011 7:11 am
That was my problem - works perfectly with the 22k box ticked.
Thank you very much Steven
Might someone be able to give me a quick one liner as to what the 22k is used for.
pennym
Re: TBS5922 Issues
Postby steven » Tue Aug 23, 2011 3:15 pm
22k used to change LNB,if 22k off the low LNB will be use,if 22k on the high LNB will be use.
Re: TBS5922 Issues
Postby Xtreme » Wed Aug 24, 2011 2:01 am
pennym Wrote:2) I get irregular pixellation (anywhere from a couple of seconds apart to a minute apart) on both Ku and C band.
Have you managed to solve your problem yet ?
Cause i have the same problem on some random s2 frequencies.
No problem on s1 frequencies though.
Xtreme
