Continiuty Error issue when CI-CAM plugged
Postby tako035 » Sat Apr 29, 2017 12:41 am
Hi everybody,
I have TBS-5590 In Turksat 42.0E only 1 channel has this issue. When I plug the Videoguard Module to 5990 the channel suddenly stops and gives continuity error. When I unplug the Module channel starts to show again. What could be the problem?
Best Regards!
tako035
Re: Continiuty Error issue when CI-CAM plugged
Postby steven » Wed May 17, 2017 2:58 pm
Hi tako035
What about the transponder information can you send to us have a check ?
Only this transponder have issue and others works well ?
Postby tako035 » Mon Aug 14, 2017 2:42 am
Hi steven
It is 12329 H 6666 2/3 @ Turksat 4A
tako035
Postby steven » Mon Aug 14, 2017 9:41 am
Hi tako035
Thanks for the information ,which driver you are using ?
Postby tako035 » Mon Aug 14, 2017 8:22 pm
Linux driver v170330
tako035
Postby steven » Tue Aug 15, 2017 10:34 am
Please have a try with our latest open source driver :
Postby tako035 » Tue Aug 15, 2017 9:49 pm
Thanks for your helps steven.
I did try it, but it didn't work for me. With the CI-CAM installed it is NDS by the way, it never worked, but with an IRDETO CAM it is working flawlessly.
tako035
