Multiple Transport Stream Receiving 6925
Postby Crashpunk » Thu Aug 18, 2011 11:16 am
How Can do to Implement the Multiple Transport Stream Receiving?? I Try with DVBDream and Progdvb, but nothing. I would like to make it work in VLC, I open a instance of VLC and work fine but open another this crash. is as if the device was in use and do not let me open another instance. Any Idea how do?? thanks
Crashpunk
Re: Multiple Transport Stream Receiving 6925
Postby Derrick » Thu Aug 18, 2011 5:52 pm
You have to select first a single multiplex with TBS6925-TSRecorder (or crazyscan). Then you can perform a scan with your favorite application but for the corresponding mux only!
Derrick
Postby feedx » Mon Dec 19, 2011 3:10 pm
9 Minutes Ago
Hi dxers my friends in great hobby
I need help.
I have TBS 6925, great Crazyscan and informed that
Readerpro 2. 7.44 have not in their folders
Tcp.dl for Multistream support.
Can someone with good installed Pro put there
that required Tcp.dl for download?
Because Lite version is unfortunately limited to
only one min
feedx
Postby sotos65 » Tue Dec 20, 2011 5:13 am
Hi feedx, take it from the attached zip...
TSReader_TCP.zip
(20.05 KiB) Downloaded 396 times
sotos65
Postby Derrick » Tue Dec 20, 2011 6:02 pm
..a tcp.dll won't change a light version into a full version :roll:
Derrick
