MULTIPLE 6909 Cards In 1 Server
Postby scottyboyz » Sun Mar 12, 2017 3:35 am
Hi there,
Ive got 5 x 6909 inside one server. I have compiled the open source driver many times and the max adapters registered in my system is 8. Had a google about and it seems i need to edit a header file somewhere and change the DVB_MAX_ADAPTERS from 8 to whatever i need. Can anyone be so kind and tell me the location of this file and where it is? Im using ubuntu 14.04.5 server 64bit.
Thanks :D
scottyboyz
Re: MULTIPLE 6909 Cards In 1 Server
Postby crazycat » Sun Mar 12, 2017 8:26 am
strange, because default DVB_MAX_ADAPTERS = 48 in tbsdtv/media_build
https://github.com/tbsdtv/media_build/c ... 4618bfc839
Postby scottyboyz » Sun Mar 12, 2017 4:34 pm
I used https://github.com/ljalves/media_build as the source.
How do you install this open source driver? is it the same way except the git location is different? I dont see any instructions thats all?
scottyboyz
Postby crazycat » Mon Mar 13, 2017 4:04 am
http://www.tbsiptv.com/index.php?route= ... th=3&id=16
Or just clone media_build and run:
./build --main-git
sudo make install
Postby ArraY » Sun Dec 31, 2017 8:46 pm
Is there any way to check in an installed Ubuntu 16.04 that value (DVB_MAX_ADAPTERS)? Any command to visualize it? So if that value is not what I want then already if what I do is rebuild the Kernel with that value. But what I want to know is if I can get that value first.
ArraY
Postby updatelee » Sun Dec 31, 2017 9:16 pm
Most distributions save a copy of the current config file in /boot you can check there.
Postby ArraY » Sun Dec 31, 2017 10:15 pm
For Ubuntu 16.04 where is find It? Which is the file config inside of /boot?
ArraY
Postby updatelee » Mon Jan 01, 2018 12:19 am
Yup sure is. You can see it there right?
Postby ArraY » Mon Jan 01, 2018 7:31 pm
Ok i found the file. But can i change the value and reboot and work perfect? Or i rebuild the Kernel?
ArraY
Postby updatelee » Mon Jan 01, 2018 10:30 pm
You must rebuild the kernel
