TBS 6909 Install build fail, linux kernel headers
Postby paule3d » Fri Mar 03, 2017 5:18 pm
just reinstalled Ubuntu 16.04 and it updated kernel during install. now I can't install TBS drivers.
at step make -j4
Preparing to compile for kernel version 4.4.0
File not found: /lib/modules/4.4.0-63-generic/build/.config at ./scripts/make_kconfig.pl line 33, <IN> line 4.
make[1]: *** No rule to make target '.config', needed by '.myconfig'. Stop.
make[1]: Leaving directory '/home/user/tbs/media_build/v4l'
make: *** [all] Error 2
Any advice please?
Thank you
paule3d
Re: TBS 6909 Install build fail, linux kernel headers
Postby paule3d » Sat Mar 04, 2017 2:28 pm
I rebooted and started Ubuntu with the older kernel 4.4.0-62 and that also fails....
home/user/tbs/media_build/v4l/videobuf2-memops.c:56:8: error: too few arguments to function 'get_vaddr_frames'
ret = get_vaddr_frames(start & PAGE_MASK, nr, flags, vec);
In file included from include/linux/scatterlist.h:7:0,
from include/linux/dma-mapping.h:10,
from include/linux/skbuff.h:34,
from include/linux/if_ether.h:23,
from /home/user/tbs/media_build/v4l/compat.h:1627,
from <command-line>:0:
include/linux/mm.h:1249:5: note: declared here
int get_vaddr_frames(unsigned long start, unsigned int nr_pfns,
scripts/Makefile.build:264: recipe for target '/home/user/tbs/media_build/v4l/videobuf2-memops.o' failed
make[3]: *** [/home/user/tbs/media_build/v4l/videobuf2-memops.o] Error 1
make[3]: *** Waiting for unfinished jobs....
Makefile:1420: recipe for target '_module_/home/user/tbs/media_build/v4l' failed
make[2]: *** [_module_/home/user/tbs/media_build/v4l] Error 2
make[2]: Leaving directory '/usr/src/linux-headers-4.4.0-62-generic'
paule3d
Postby steven » Sat Mar 04, 2017 8:11 pm
#wget http://www.tbsdtv.com/download/document ... 19.tar.bz2
#tar jxvf media_build-0119.tar.bz2
#cd media_build
#./install.sh
#reboot
Postby paule3d » Sat Mar 04, 2017 9:20 pm
OK, this didn't work with kernel 4.4.0-63 and I think .62 was the same.
so I installed 4.4.0-21, rebooted, choose advanced Ubuntu options, select kernel .21 and now I have 8 adapters in /dev/dvb
Thank you
paule3d
