TBS5922 not working with NAS
Postby mimo424 » Thu Mar 02, 2017 11:02 pm
I have a tbs5922 usb tuner which iam using with a DS212j. When i first received the tuner and plugged it in the NAS it worked immediately and tvheadend even detected the card.
everything was working fine until suddenly the tuner stooped working and is now not even detected by the NAS.
I have not done anything, everything just stooped working
here is a sample of dmesg when it used to work:
[Sat Feb 11 21:25:20 2017] usbcore: registered new interface driver dvb_usb_ttusb2
[Sat Feb 11 21:25:22 2017] usbcore: registered new interface driver dvb_usb_dib0700
[Sat Feb 11 21:25:23 2017] au0828 driver loaded
[Sat Feb 11 21:25:23 2017] usbcore: registered new interface driver au0828
[Sat Feb 11 21:25:24 2017] usbcore: registered new interface driver dw2102
[Sat Feb 11 21:25:25 2017] usbcore: registered new interface driver pctv452e
[Sat Feb 11 21:25:25 2017] usbcore: registered new interface driver tbsqbox2ci
[Sat Feb 11 21:25:26 2017] usbcore: registered new interface driver tbsdvbc
[Sat Feb 11 21:25:26 2017] usbcore: registered new interface driver tbs5680
[Sat Feb 11 21:25:27 2017] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in cold state, will try to load a firmware
[Sat Feb 11 21:25:27 2017] usb 1-1.1: firmware: requesting dvb-usb-tbsqbox-id5922.fw
[Sat Feb 11 21:25:27 2017] dvb-usb: downloading firmware from file 'dvb-usb-tbsqbox-id5922.fw'
[Sat Feb 11 21:25:27 2017] tbsqbox22: start downloading TBSQBOX firmware
[Sat Feb 11 21:25:27 2017] dvb-usb: found a 'TBS QBOX22 DVBS2 USB2.0' in warm state.
[Sat Feb 11 21:25:27 2017] dvb-usb: will pass the complete MPEG2 transport stream to the software demuxer.
[Sat Feb 11 21:25:27 2017] DVB: registering new adapter (TBS QBOX22 DVBS2 USB2.0)
[Sat Feb 11 21:25:27 2017] dvb-usb: MAC address: 00:22:ab:c0:23:e9
[Sat Feb 11 21:25:28 2017] TurboSight TBS 5922 Frontend Attaching...
[Sat Feb 11 21:25:28 2017] QBOX22: TBS5922FE attached.
[Sat Feb 11 21:25:28 2017] usb 1-1.1: DVB: registering adapter 0 frontend 0 (TurboSight TBS 5922 DVBS/S2 frontend)...
[Sat Feb 11 21:25:28 2017] input: IR-receiver inside an USB DVB receiver as /devices/platform/orion-ehci.0/usb1/1-1/1-1.1/input/input0
[Sat Feb 11 21:25:28 2017] dvb-usb: schedule remote query interval to 150 msecs.
[Sat Feb 11 21:25:28 2017] dvb-usb: TBS QBOX22 DVBS2 USB2.0 successfully initialized and connected.
[Sat Feb 11 21:25:28 2017] usbcore: registered new interface driver tbsqbox22
[Sat Feb 11 21:25:28 2017] usbcore: registered new interface driver Abilis Systems as10x usb driver
[Sat Feb 11 21:25:29 2017] usbcore: registered new interface driver dvb_usb_it913x
[Sat Feb 11 21:25:29 2017] usbcore: registered new interface driver dvb_usb_dvbsky
and here is how dmesg looks like now when I plug in the USB tuner:
[Wed Feb 15 16:01:55 2017] Initializing USB Mass Storage driver...
[Wed Feb 15 16:01:55 2017] usbcore: registered new interface driver usb-storage
[Wed Feb 15 16:01:55 2017] USB Mass Storage support registered.
[Wed Feb 15 16:01:56 2017] usbcore: registered new interface driver usblp
[Wed Feb 15 16:01:56 2017] usbcore: registered new interface driver hiddev
[Wed Feb 15 16:01:56 2017] usbcore: registered new interface driver usbhid
[Wed Feb 15 16:01:56 2017] usbhid: v2.6:USB HID core driver
[Wed Feb 15 16:02:03 2017] ata2.00: configured for UDMA/133
[Wed Feb 15 16:02:03 2017] ata2: EH complete
[Wed Feb 15 16:02:06 2017] ata2.00: Disable disk write cache in EH
[Wed Feb 15 16:02:06 2017] ata2.00: configured for UDMA/133
[Wed Feb 15 16:02:06 2017] ata2: EH complete
[Wed Feb 15 16:02:06 2017] sd 1:0:0:0: [sdb] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[Wed Feb 15 16:02:07 2017] loop: module loaded
I do have the firmware file under /lib/firware: dvb-usb-tbsqbox-id5922.fw
does it look like the firmware is not loaded? Can someone please tell me what is going on?
Thanks in advance
mimo424
Re: TBS5922 not working with NAS
Postby steven » Fri Mar 03, 2017 9:24 am
Please have a try use the 5922 in your PC check whether is ok
Postby mimo424 » Fri Mar 03, 2017 4:31 pm
Hi Steven and thanks for the fast reply,
I actually did that, after plugin it to my laptop and installed the drivers the tuner was recognized and worked properly. So it seems like a linux issue.
/M
mimo424
Postby steven » Fri Mar 03, 2017 5:10 pm
This means the 5922 is ok , maybe you can have a try reburn your NAS system ?
Postby mimo424 » Fri Mar 03, 2017 8:42 pm
Hi againe,
Ive done that, Iv even reinstalled the NAS software, but still nothing works. The only thing that i have not been able to do is to install the linux drivers for the tuner on the NAS. I could not compile my own drivers. I need to try to install the drivers but unforunately i dont know how to build for this system.
the NAS sytem is the following
uname -a:
Linux Terrabit 2.6.32.12 #15047 Tue Feb 14 02:38:24 CST 2017 armv5tel GNU/Linux synology_88f6281_212j
So its based.
btw ive tried following the guid on this website : https://github.com/ljalves/linux_media/wiki but it i was not able to make my drivers.
maybe you or someone else knows how to do it?
/M
mimo424
Postby crazycat » Sat Mar 04, 2017 3:56 am
You have very old kernel and ARM V5 CPU.
You need at least 3.10 lts kernel and ARM v7.
old linux-tbs-drivers support only x86/x86_64 arch.
Postby mimo424 » Sat Mar 04, 2017 6:43 pm
Hi crazycat and thanks for your answere.
But it used to work. why has it just suddenly stop working?
/M
mimo424
Postby crazycat » Sun Mar 05, 2017 5:37 am
work on arm cpu ? :)
Postby mimo424 » Mon Mar 06, 2017 4:53 pm
yes! :). I was able to fix it now! it seems like when installing DVB link on the NAS the drivers are installed together with it. So now its working in tvheadend :). Thanks a lot for your help!
/M
mimo424
