i2c xfer timeout
i2c xfer timeout
Postby pyvet » Wed Mar 01, 2017 7:35 pm
I have TBS 6909 and Cesbo Astra. If I use 4 adapters (number 0, 1, 2, 3) - everything works well. But if
I add the adapter 5 - signal disappears on all adapters and get error messages "i2c xfer timeout" when server restart. Who has the same problem? How to fix it?
pyvet
Re: i2c xfer timeout
Postby steven » Thu Mar 02, 2017 2:40 pm
Can you tell us that which driver you are using ? please use our latest open source driver :
Postby pyvet » Thu Mar 02, 2017 7:32 pm
pyvet
Postby steven » Fri Mar 03, 2017 9:26 am
Thanks for your update ,please have a try change the PCI-E slot and is this always happen when you add the 5 tuner ?
Postby pyvet » Fri Mar 03, 2017 3:48 pm
I TRIED DIFFERENT MOTHERBOARD. NOTHING HAS CHANGED. THE SIGNAL LOSS WAS GOING ON ALWAYS ADDING NEXT ADAPTER (NUMBER 5)
pyvet
Postby steven » Fri Mar 03, 2017 4:00 pm
Please have a try direct using tuner 5 check whether is ok
Postby PortalNET » Sat Jun 02, 2018 6:14 am
i2c xfer timeout
hmm looks like he is having same trouble as i am , this card TBS6909 i have all 8 tunners
working, just getting Vertical TP signal...
i have 1 cable that connects direct single band no diseqc switch enabled nothing.. just 1 single cable coming from sat dish direct to tunner 0 connected, and from there i have 8 TPs working all on Vertical Position,
after couple of hours start getting all this kernel and i2c error timeout messages on the log and cards starts shutting down i know its a driver problema, because here lsdvb command stop responding with error message like pyvet user posted..
if i reboot the PC server this works ok for couple of hours untill same problem occurs..
PortalNET
