Stream to HTML Page
Stream to HTML Page
Postby sip03ds » Wed Jan 25, 2017 10:21 pm
I am trying to create a web page to stream HTTP to HTML page.
I am using HTML 5 video tag - but the steam does not appear on the web page.
Is there a particular reason that I do not get the stream?
The stream appears using VLC - and I am able to display video on the web page using VLC Browser Plugin.
The problem is that in case I am using VLC I cannot display the stream to mobile devices.
I really appreciate any help on the case.
sip03ds
Re: Stream to HTML Page
Postby echomay » Tue Feb 28, 2017 5:25 pm
Tbs2603 support http stream not hls stream, if you want play the stream on the web, you need translate the stream from http to hls, use some software, like ffmpeg.Thanks.
echomay
Postby Alegpl » Mon May 29, 2017 5:09 am
is the hls streaming a feature that can be introduced with a new firmware?
Regards
Alegpl
