TBS5520SE and Crazyscan
Postby assemblersat » Sat Jan 14, 2017 5:23 am
Hello ,
i would buy this USB Card and use it with Crazyscan EBSpro
is TBS5520SE supported by crazycats streamreader for using on crzyscan?
thanks for infos
assemblersat
Re: TBS5520SE and Crazyscan
Postby steven » Sat Jan 14, 2017 12:01 pm
The crazyscan support card you can check here:
https://sourceforge.net/p/crazyscan/wiki/Info/
for 5520se have not added yet
Postby assemblersat » Sun Jan 15, 2017 2:45 am
steven Wrote:Hi
Thank you for Info
assemblersat
Postby momi133 » Wed Nov 01, 2017 12:17 am
steven Wrote:Hi
Hi Dear
crazy cat add this card to crazyscan and support blindscan.
please add device to tbs-blindscan and ts-recorder.
thanks
momi133
Postby shark » Thu May 03, 2018 1:09 pm
Esta placa 5520se nao é possive fazer blindscam no ebspro?
Diz que nao é suportado. Ha alguma solucao ?
shark
