driver 2.0.0.6 not work for Windows 10 (solved)
Postby imago » Sat Jan 07, 2017 10:16 pm
good day
there are plans work to release drivers for Windows 10 version 1607 (Anniversary Update), or what are the options to work on 2.0.0.6 ?
ps I tested on two different motherboards Z87E-ITX and Z87-DELUXE, Windows 10 version 1607 (Anniversary Update) all unknown device. In Linux CrazyCat and TBS driver the device works without problems
imago
Re: driver 2.0.0.6 not work for Windows 10 (Anniversary Upda
Postby MrFloppy » Fri Aug 04, 2017 5:38 pm
Sry for double posting: Just got a TBS5925 as well and ran into a similar problem on W10AU: code 10, could not start device.
The driver from the CD-ROM installs fine, but I dont get any signal. I'ld like to be able to use the latest drivers as offered to test the setup.
MrFloppy
Postby steven » Mon Aug 07, 2017 4:10 pm
For 5925 the win10 driver use this win10 driver :
https://www.tbsiptv.com/download/tbs592 ... .0.0.6.zip
Postby MrFloppy » Tue Aug 08, 2017 12:13 am
I tried both versions, the "normal" one and the one for W10, similar results as shown with the screenshots. The driver from the CD (v1.0.2.6) installed just fine, but I have to force the "installation" of the 2.0.0.6 version (it does not seem to bee recognized as a compatible driver) - which then fails. I'm not sure why, though.
MrFloppy
Postby imago » Thu Aug 31, 2017 11:22 pm
The problem was solved by installation Windows 10 (assembly of 15063.540) Version 1703
After updating all works
ps (assembly of 14xxx) Does not work
imago
