Upgrade MOI+ to 1.0.2
Postby pistacio » Fri Dec 30, 2016 6:04 am
I cannot flash/upgrade MOI+ to the latest version 1.0.2. I've read that there are 3 files, uboot, kernel and system files, but on http://www.tbsdtv.com/download/ I can find only the kernel and system.
When performing the flash/upgrade of system with an USB key the display indicates the percent progress of System until 99%, then it restarts to 0% and does never move. Of course the upgrade doesn't succeed. Tried with both kernel and system files at once and only system file present on USB key. Flashing only the kernel does work though.
One more thing, MOI+ does not boot without an USB key plugged in.
pistacio
Re: Upgrade MOI+ to 1.0.2
Postby Yenom » Tue Jun 20, 2017 1:49 am
I have the same issue?have emailed support but emails are ignored?
Yenom
Postby QTIP » Wed Jun 21, 2017 4:29 pm
Same issue here
QTIP
Postby steven » Thu Jun 22, 2017 2:57 pm
Here is the u-boot please have a check
MOI2921_uboot.zip
u--boot
(194.5 KiB) Downloaded 1820 times
Postby QTIP » Mon Jul 03, 2017 5:27 am
Thanks Steven.
Works like a charm!
QTIP
Postby wynasoft1 » Fri Jul 21, 2017 7:14 am
I have the same issue how use this file?
thanks
wynasoft1
Postby steven » Mon Jul 24, 2017 9:26 am
check this file and put all update files to USB disk
https://www.tbsdtv.com/download/documen ... I+V1.1.pdf
Postby grepaly » Wed Sep 13, 2017 2:41 am
Hi, I have the same problem with my MOI+. I did put all three files, it counts until 100, then it goes to "System: 0%", and nothing happens. I tried multiple usb drives, mostly they did not even boot (all of them were formatted fat32). Any idea what else could I try?
Thanks, Andras
grepaly
Postby steven » Fri Sep 29, 2017 6:18 pm
Please do not forget format your USB disk to FAT32 and only one partion .
Return to MOI+
