Setup static-IP in Moi Pro AMD
Postby slepac » Tue Dec 20, 2016 2:12 pm
Hi Guys,
I have a problem with my Moi Pro AMD ( Firmware 2.0.0.1)
I would like to setup my static-IP. I fill out the field for the static-IP and save it, but it doesn't work. The field to put the static-IP it's still empty, after the saving progress.
Please could you explain me why it doesn't works. Maybe there is an technical issue in the hard- or software.
I hope someone can help me.
Thank's in advance.
Kind regards,
Slepac
slepac
Re: Setup static-IP in Moi Pro AMD
Postby xiaocao » Wed Mar 01, 2017 5:48 pm
hi ,
set static ip for LAN 1 will edit the file /etc/sysconfig/network-scripts/ifcfg-enp1s0f0 .
set static ip for LAN 2 will edit the file /etc/sysconfig/network-scripts/ifcfg-enp2s0 .
if the static ip was not saved , please check this file .
if also has the issue , please wirte email to jack@tbsdtv.com .
best regards!
xiaocao
Return to MOI Pro - AMD
