How to Install TV Tuner PCI-e Cards in MOI Pro AMD?
Postby Jenny » Fri Dec 09, 2016 11:40 am
Dear All,
Nice day for you guys. If you wanna know how to install TV tuner PCI-e cards in MOI Pro AMD IPTV streaming server, you should not miss the following tutorial video. ;)
https://youtu.be/Ew-E70LQfLk
MOI Pro AMD ( Named: TBS2951) is a new professional IPTV streaming server powered by AMD Embedded G-Series SoC. It can receive live TV signal using built-in TV tuners and stream the channels further through Ethernet to various client devices, such as PC, tablet PC, smartphone, and smartTV.
Key Features
1. [/list]Live SD/HD TV streaming
2. Based on AMD Embedded G-Series SoC
3. High-performance graphics processing
4. Low power consumption
5. Compliant with Linux / Windows OS
6. Linux Open Source software support: Kodi( XBMC), OpenPCTV, VDR
7. Supports up to 16 TV tuners (4 TV tuner PCIe cards) of different DVB standard
8. Supports DASH (Desktop and Mobile Architecture for System Hardware) remote management
Links for your reference: http://www.tbsiptv.com/iptv-streamer/moi-pro-amd-professional-iptv-streaming-server
It would be much appreciated for you to leave feedback or share your ideas. Thanks. :)
Best Regards,
Jenny Feng
TBS Technology
Jenny
Re: How to Install TV Tuner PCI-e Cards in MOI Pro AMD?
Postby sofiakerry » Thu Jul 06, 2017 2:32 pm
An antenna tuner or antenna tuning unit is a device connected to a radio transmitter or receiver and its antenna in order to improve the effectiveness of the power transfer between them. informative thread Jenny! the video linked you shared is too helpful, I installed TV tuner card with the help of this.
fast cccam
sofiakerry
Return to MOI Pro - AMD
