Fetching multiple MIS streams
Postby titer » Tue Dec 06, 2016 4:03 pm
Hi there,
I have been testing a TBS6908 card for acquiring MIS streams and that has been doing well (thanks to instructions from http://www.tbsdtv.com/forum/viewtopic.php?f=167&t=9707), as I have been able to receive various MIS streams from Eutelsat 5.0W and 12.5W, on Debian 8 with the open source drivers.
One question I have is: looking at for example the transponder http://en.kingofsat.net/tp.php?tp=6583, Eutelsat 5.0W 11637V carries 6 streams. As far as I can tell, the linux drivers & DVB API only let you select one stream at a time, so I would need 6 inputs to receive them all.
Is this a hardware or software limitation, would there be any possibility to extract all streams in parallel from a single input?
Thanks,
Eric
titer
Re: Fetching multiple MIS streams
Postby crazycat » Wed Dec 07, 2016 3:13 am
HW limitation, one demod path can process only one TS from S2 frames.
P.S. you can use also 6905.
Postby titer » Wed Dec 07, 2016 11:57 pm
Ok, thank you for clarifying that.
Going a little off-topic here, but my understanding from looking at the 6905 and 6908 specs was that, only the latter supports ACM/VCM in addition to CCM, which would be needed for many MIS feeds. Did I get that wrong, and then in which case would one need the 6908?
titer
Postby crazycat » Thu Dec 08, 2016 11:21 am
STV0910BD demod (TBS6905) have restricted support for VCM/Multistream DVB-S2/QPSK,8PSK. So can receive multistream 8PSK transponders with DTT muxes.
"Advanced" demod STV0910AD (TBS6983,6903,6908,5927) demod have full support ACM/VCM DVB-S2/QPSK,8PSK,16APSK,32APSK.
Postby igorfreire » Sun Dec 15, 2019 1:51 am
I was looking for information regarding concurrent multistream reception and found this useful post.
I have a DVB-S2 lab setup with a Tx node directly connected to TBS 5927 and the TBS 5520SE receivers and I would like to accomplish something similar: to multiplex two streams and receive them both simultaneously.
The Tx node is sending UDP/IP traffic over MPE, over MPEG TS. At TS level, it multiplexes two PIDs, 32 and 33. All TS packets with PID 32 are sent over DVB-S2 frames using MODCOD QPSK 1/4, whereas all TS packets with PID 33 are sent over DVB-S2 frames using MODCOD 8PSK 3/5. So, in the end, in this scheme (labeled Scheme 1 below) two logical data streams are multiplexed at TS level. On the receive side, then, I instantiate two dvbnet interfaces, one for each PID, and expect to receive the UDP/IP packets sent on the corresponding PID.
In summary:
Scheme 1 (same ISI, different PID):
Stream 1: ISI = 0; PID = 32; MODCOD = QPSK 1/4
Stream 2: ISI = 0; PID = 33; MODCOD = 8PSK 3/5
Using this scheme, I've found that:
- The TBS 5927 correctly demodulates the VCM stream and decodes both MPEG TS PIDs.
- The TBS 5520SE locks randomly to one of the two streams. I don't seem to be able to control which stream/MODCOD the 5520SE locks to using dvbv5-zap.
Due to the problem with the 5520SE, I tried multiplexing at BBFRAME/ISI level. The scheme becomes:
Scheme 2 (different ISI, different PID):
Stream 1: ISI = 1; PID = 32; MODCOD = QPSK 1/4
Stream 2: ISI = 2; PID = 33; MODCOD = 8PSK 3/5
This scheme does allow me to control which stream the 5520SE locks to. All I need to do is set STREAM_ID on channel.conf used by dvbv5-zap. However, the disadvantage is that I don't seem to be able to receive both streams simultaneously when they use distinct ISI as in Scheme 2 above. Hence, although Scheme 2 solves the 5520SE problem (of choosing which MODCOD to lock to), it is a worse solution for the 5927, with which it would normally (in Scheme 1) be possible to receive both streams simultaneously.
crazycat Wrote:HW limitation, one demod path can process only one TS from S2 frames.
So, is it possible to receive multistream simultaneously with either the TBS5927 or the TBS5520SE? If I understand correctly, the 5927 uses the STV0910 demod that was mentioned above. So I suppose it is not possible?
igorfreire
