missing signal
missing signal
Postby charly77 » Fri Nov 25, 2016 6:15 pm
we use a Gopro Hero 3+ and a Replay Prime X
this cameras need a signal from the monitor (in this case the tbs2603) to switch on the HDMI
at the moment the HDMI is off/goes off, if we plug the camera to the TBS2603
if we use a HDMI Splitter, the camera works (get's the information from the monitor)
I think it's the missing EDID information
is there any chance with a updated firmware to get this signal?
charly77
Re: missing signal
Postby echomay » Tue Dec 13, 2016 9:43 am
Maybe you can change the hdmi cables and try again, some old cables not supoort hdmi signal so good.
echomay
Re: missing signal
Postby charly77 » Tue Dec 20, 2016 5:32 am
echomay Wrote:Hi,
Tried many different cables
the camera need an edid information, the encoder give not this information
with a Lindy EDID Emulator (32103) , connected to the camera, everything works
so why do rthe encoder not give the EDID information?
charly77
Re: missing signal
Postby charly77 » Sat Mar 25, 2017 8:17 pm
Tried it with the new firmware (85)
no success
charly77
Re: missing signal
Postby echomay » Tue Mar 28, 2017 11:59 am
I will check about EDID, please give me your email, if i have a resoult, i will send you, mine is echo@tbsdtv.com.
echomay
Re: missing signal
Postby charly77 » Wed Oct 11, 2017 4:53 pm
we have two of the encoders
one with firmware 0.99 EDID is OK
camera switches on the HDMI if connected and startet
the other with firmware 0.85, 0.99 and 1.12 no EDID signal
the camere will not switch in the HDMI if it's connected to the encoder
only if I connected the camera to a monitor, switch it on and the (very fast) connect it to the encoder, it works
how can we solve this problem?
charly77
