tbs5520 and bsod
tbs5520 and bsod
Postby wolfgr » Fri Nov 25, 2016 6:14 pm
hello ,i bought a tbs5520 to use with my win10 htpc so i can watch free sat programs with nextpvr/kodi.I have installed newest drivers and the usb tuner at dvb-s2 mode.When i try to scan channels the scanning begins but soon i get a bsod with the message "apc index mismatch".Tried many times using other dvb programs as dvbdream and dvbviewer and i get the same result.I tried to a fresh win10 instalation still the same bsod when scanning.I even installed the tuner at another win10 computer but nothing changed.I think it is a driver issue?
wolfgr
Re: tbs5520 and bsod
Postby steven » Mon Dec 12, 2016 11:23 am
Which USB port you are using ? if you are USB 3.0 port please change to USB 2.0 port
