[ Moderator Control Panel ]
by crapok » Sat Oct 29, 2016 12:09 am
i have buy a TBS6905 card and it comes with a 12v power cable (yellow & black).
Do i need to plug this additional cable ? (it seems the card is working without).
crapok
by crapok » Mon Oct 31, 2016 7:00 pm
If someone else was interested answer is : You don't need to use external power cable, if you don't have heavy power consume Dish device.
crapok
by steven » Thu Nov 03, 2016 11:26 am
Usually do not need to use the extra power supply ,just when you connect a big motor the power from PCI-E slot is not enough
then you need to use the extra power .otherwise you do not need to care about this .
