TBS 5990 suddenly not work on Linux
Postby nasuel » Fri Oct 21, 2016 3:00 pm
yesterday my Tvheadend machine crashed and after reboot the TBS 5990 adapter did not work. There was no kernel update done so the driver should work like yesterday. When i look into dmesg i see the fallowing line
[ 17.164635] cx231xx 1-3:1.1: Failed to attach demod tas2101 0
Did anybody know what i can do?
Thanks a lot
Regards
nasuel
Re: TBS 5990 suddenly not work on Linux
Postby steven » Mon Oct 24, 2016 11:20 am
Hi nasuel
Please have try reinstall the open source driver :
before install delete your current kernel media folder.
rm -rf /lib/modules/`uname -r`/kernel/drivers/media/*
Then start reinstall check whether will be ok
Kindd Regards
Postby nasuel » Tue Oct 25, 2016 6:15 pm
Hi steven,
i tried to reinstall the driver but after installation the problem still exists
[ 17.295052] DVB: registering new adapter (cx231xx #0)
[ 18.180592] cx231xx: Failed to attach demod 0
[ 18.180648] cx231xx: Cx231xx dvb Extension initialized
I will test the 5990 with Windows tonight and give feedback.
Regards
nasuel
Postby steven » Wed Nov 09, 2016 6:03 pm
Hi nasuel
What about your test report is it ok in windows ?
If in windows you still have problem you can send an email to our support#tbsdtv.com
