MOI Pro – AMD with TBS 6909 does not work with 110W 119W
Postby globetv2016 » Thu Sep 29, 2016 4:57 am
Hi folks want to tell everyone that after buying moi amd pro with 4X6909 cards i figured out it does not work with 110W 119W and 129W.
Why : i think i figured out after hitting my head so many days that all these satellite uses DVB-S 8psk , not DVB-S2 8psk.
i tried to ask support no one give straight answer and even dont reply ur email on this topic.
I want this to work even i am ready to buy another card if exists for DVB-S 8psk.
Affect: Because its 6909 just support demodeulation DVB-S qpsk, and 110W 119W and 129W are on DVS-S 8psk , so it will not lock any of signal and will not find channels .
Specifications:
Frequency range: 950~2150 MHz
Signal Level: -85~-10dB
Symbol rate: 1~45Msps
Demodulation:
DVB-S QPSK, DVB-S2 8PSK
FEC:
DVB-S2
8PSK: 3/5, 2/3, 3/4, 4/5, 5/6, 8/9, 9/10
DVB-S
QPSK: 1/2, 2/3, 3/4, 5/6, 7/8
DiSEqC support: 1.0, 1.2, 2.x
so my question to support what you suggest in this scenario
i request to support team to provide solution on this by doing that i can save almost my 2000 USD.
globetv2016
Re: MOI Pro – AMD with TBS 6909 does not work with 110W 119W
Postby steven » Mon Oct 10, 2016 3:16 pm
As we already discussed with email the transponder is 8psk turbo :
8psk turbo
Return to MOI Pro - AMD
